To Install or Not Install Differential Drop Kit After Lifting A TRD Offroad Tacoma
Great White North
Glenn
TRD Off-Road Premium 2024 Tacoma, 2018 Rav4 Toyota
I recently installed Peak’s 2.0 Aluminum Explorer Kit and Core's 4x4 Rear Suspension Kit on my 2024 TRD Off Road Tacoma, which raised the truck by 2 inches. Visually, the CV joint angle seems unchanged, so I’m unsure if I should install a Differential Drop Kit to prevent additional stress on the CV joints. Some recommend it after lifting beyond OEM specs, while others only suggest it for lifts over 4-5 inches. Any experience-based advice would be appreciated.
2024 Tacoma To Install or Not Install Differential Drop Kit After Lifting A TRD Offroad Tacoma 1768866919895-76
2024 Tacoma To Install or Not Install Differential Drop Kit After Lifting A TRD Offroad Tacoma IMG_1881
2024 Tacoma To Install or Not Install Differential Drop Kit After Lifting A TRD Offroad Tacoma IMG_1882
2024 Tacoma To Install or Not Install Differential Drop Kit After Lifting A TRD Offroad Tacoma CoreRearSuspension1
2024 Tacoma To Install or Not Install Differential Drop Kit After Lifting A TRD Offroad Tacoma IMG_1883
2024 Tacoma To Install or Not Install Differential Drop Kit After Lifting A TRD Offroad Tacoma IMG_2058
2024 Tacoma To Install or Not Install Differential Drop Kit After Lifting A TRD Offroad Tacoma IMG_2059
2024 Tacoma To Install or Not Install Differential Drop Kit After Lifting A TRD Offroad Tacoma 1768866872083-w2
2024 Tacoma To Install or Not Install Differential Drop Kit After Lifting A TRD Offroad Tacoma 1768866899064-ec
395North
TRD PreRunner
CA
2025 TRD PreRunner
Posting a few shots of your CV angles/boots would be helpful...
Wife bought my 24 TRD
Anthony
Aberdeen Wa
I wouldn't recommend it. Toyota installed my king lift and would not install a diff drop. Due to the vibrations caused. If you're feeling any kind of vibration I recommend doing a ECGS bushing replacement. With the king left, I am getting 2.5 overstock height. With the bushing, and spring replacement, I was able to get it up over 3 with no vibrations. Food for thought.
AZTaco
AZ
2025 Tacoma TRD Pro
I would hope that Peak did some engineering and testing when they developed their kit. What do they recommend?
Separately, with only 1" of rear lift you probably didn't need to adjust your rear control arms or track bar but since they are adjustable did you check/adjust for alignment?
JayTech
Jay
2025 Toyota Tacoma TRD ORP
I would not bother doing a diff drop. It really isn't worth it in my opinion. Especially for lifts under 3". The worst that will happen is the needle bearing on the axle might start to make noise or cause vibrations which at that point I would recommend the ECGS bushing(Something that is honestly an upgrade for these trucks anyways). I have lifted a few trucks over the years and have never done a diff drop. The very minor change in the C/V angles is less impactful than changing the pinion or driveshaft angles which may actually produce more vibrations. For lifts over 3" you should be getting a proper lift that corrects all driveline angles.
Great White North
Great White North
Glenn
Thanks for the feedback and recommendations.
395North
TRD PreRunner
CA
2025 TRD PreRunner
The angles don't look horrid. The bellows of the boots (especially the inner boot) look like they are making contact, so while angle themselves may not result in binding, premature boot wear may be in your future.
For what it's worth I'd dial the lift down before I did a diff drop.
Great White North
Great White North
Glenn
I just heard back from Peak support "We haven't seen the need for a diff drop on the 4th gen trucks just yet and we haven't seen anything in the way of CV failures either. "
Great White North
Great White North
Glenn
FYI Icon diff drops have in some cases caused bad vibrations. Not sure why?
