MustardTiger
MustardTiger
TacoMAX/SDuty/Dmax
Finally got my JBL speaker grill swapped over. Not an easy process!! After removing it from the original A pillar trim, I was able to use only 1 screw post - the one closest to the point/tip. I used JB Weld as the adhesive…which seems to have worked, after being clamped overnight. After cured I followed up with a bit of Lexel sealant in spots. Overall it turned out, but I wouldn’t recommend doing it unless you have lots of patience and diligence. You gotta be creative too in how you clamp it
It still pisses me right off that Toyota didn’t make the truck with a drivers side handle.
2024 Tacoma Driver's side grab handle available IMG_7783
greenno
San Diego Cal.
2026 Tacoma Offroad
Too bad they don’t make a replacement pillar with handle without the faux speaker grill for those of us that don’t have the JBL option on our trucks. Look kinda odd having a grill on drivers side only.
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
Nice work! I’m pissed about this too, but I am pretty sure it’s because, in an accident, the airbag would force anything sticking out further into the driver’s skull.
MustardTiger
MustardTiger
TacoMAX/SDuty/Dmax
That could be true...but that logic doesn't align with the passenger side handle lol. I'm thinking it's more to do with visibility. Regardless...I'm happy it's done, and I hope that it holds up. Finding an adhesive to effectively work with Polypropylene, Polyethylene and EPDM plastics is nearly impossible. If anyone is looking to do this on their truck, DM me and I'll try to give you some tips based on my experience doing this
lauren01
Lauren
Ventura, CA USA
Maybe Velcro could do the trick.
bigcanoe
Arn
Moncure NC
Toyota Rav4
Would countries with right hand drive have the OEM version to match what we have on our passenger side?
Deacon
Scott
Kentucky
24 Tacoma TRD OFFROAD
To bad no one makes, that I've found, a REAL handle. Like the one right behind ur head for back doors??!?!?!?
IDont understand the change? I've seen aftermarket for GEN3 and looks nice. Anyway Its just one of the little things that are no-brainers....thanks
