Wife bought my 24 TRD
Anthony
Aberdeen Wa
Dude...we get it, we know what your truck looks like. If you're going to keep posting, at least try to contribute something meaningful to the thread rather than just showing off your truck.
I just did, sorry if you didn't find it informational.
Just saying WHO installed the lift.
I have 2025 OR with the Readylift SST 2.1. For those who have installed the ECGS bushing kit on a 4th Gen, do you get a slight rhythmic vibration over 35 mph? It’s not drastic, but I can feel it in the steering wheel. Is this normal after the bushing install? Forgot to mention the vibration is lessened when I put it in 4WD (similar to when I had the needle bearing).
No, after installing the vibration went away. However either way 4Hi at higher speeds is not “smooth” so yes and no 😎
Mtnbikes
Minnesota
Are you saying you still have some vibration even after installing the new bearing?
fzjeddie
fzjeddie
Eddie
Phoenix, AZ
2024 Tacoma SR5 4x4
On mine, it eliminated the vibration 100%. I only have the front 2” raised and also have a diff drop installed
Mtnbikes
Minnesota
I just had the Eibach Pro Truck 2r installed; 2” in front. Everything is dialed in, however I do have mild vibration started at 68mph. I’m assuming it’s the bearings. Not sure if I should wait or have them swapped out sooner?
fzjeddie
fzjeddie
Eddie
Phoenix, AZ
2024 Tacoma SR5 4x4
Are you talking about wheel bearings or the diff needle bearing?
No, but when at hiway speed pulling a hill under load you can feel that it’s in 4X4. It’s not really a vibration but you can feel the difference.
fzjeddie
fzjeddie
Eddie
Phoenix, AZ
2024 Tacoma SR5 4x4
Yes, I meant needle bearing.
I drove mine for about 5000 miles before adding the bushing and my bearing had no damage. I have seen pictures of the needle bearing getting shelled, but I’m not sure how long they ran it. You’ll be safe for a little while
Mtnbikes
Minnesota
I find it really annoying that a 2” difference would cause this. What are people doing if they buy one with a factory lift?
fzjeddie
fzjeddie
Eddie
Phoenix, AZ
2024 Tacoma SR5 4x4
I’m very curious about this. They sell a lot with a front lift but all the ones I saw for sale where I am are 2wd
