- Joined
- Jan 30, 2026
- Threads
- 7
- Messages
- 66
- Reaction score
- 31
- Location
- united states
- Vehicle(s)
- 2025 tacoma SR5
Anyone try a transmission cooler yet?
Just out of curiosity and testing a theory, what drive mode were you in on the first attempt?Yes. I did a hill climb and the truck shut itself down because the trans temp got too hot. Then I got the Mishimoto trans cooler, did the same climb in the same weather conditions and the gauge got only a little above midway. No issues climbing. I talked to Cam from Cam tuning and Cobb doesn't have a setting on the access port for trans temp. So I'm not able to get real numbers. It seems to have literally everything else in terms of data. My truck is also tuned. FYI. I personally recommend the trans cooler. I'm looking forward to this summer to see how much it helps.
Some have posited that sport mode, and even more so, manual mode, makes the trans lock up more fully, reducing temps.It was in normal. I only started using sport mode after I tuned it. Even now I forget to put it into sport mode sometimes.
