Best front skid plate for oil changes? Thoughts on Cali Raised?
JohnSadler
Moore, OK
Toyota Tacoma TRD Off Road iForceMax Premium
I’m trying to figure out which engine skid plate I want. I like the C4 skid but don’t like how you lose your access to your front tow hooks. I’m leaning towards Cali Raised but am curious on everyone’s experience with oil changes with that skid plate. I was also considering Miller Cat but it’s out of stock and has been for a few weeks. Thanks!
Mtnbikes
Minnesota
Get Miller Cat. Great product and allows for easy access to oil plug and filter. It will be worth the wait.
Deleted User 412290
Just FYI if you don't have one: TRD, Trailhunter, and Landcruiser skids you can drop in less than a minute with their design. Loosen 2 bolts, remove the other 4, twist the plate and you're done. Goes on just as easy. No risk of mess through the access holes and you can inspect under the plate for any leaks during your oil change. I was gonna upgrade to an aftermarket, but decided to stick with the OEM design due to how fast and easy it is to remove.
With the sale going on now you can get a tempered steel Trailhunter skid for $232, tempered steel "Toyota" stamped Landcruiser skid (like the one below) for $244, or TRD aluminum for $310.
Hard to beat the price, OEM fit, and easy oil change access v.s. anything aftermarket ! Plus the Landcruiser and Trailhunter skids link up with transfer case skid and rear diff skid all 3 for less than $800. Hard to beat!
nurp42
TRD PreRunner
'24 PreRunner
+1 on the Miller Cat plate——makes oil changes an absolute breeze (the only snag I run into is my seeming inability to read/see the oil level on the dip stick :unsure: ).
Deleted User 412290
+1 on the MCX plate——makes oil changes an absolute breeze (the only snag I run into is my seeming inability to read/see the oil level on the dip stick :unsure: ).
Fumoto? Even easier than dropping the skid! Nice.
Do you just pull the plate intermittently to check underneath ?
nurp42
TRD PreRunner
'24 PreRunner
Correct. The long nipple version of the Fumoto valve allows for easy attachment of tubing w/ a small hose clamp (nothing special req'd----just whatever's available at local hardware store). I keep the tubing tucked up in the skid plate and simply pull it down through the opening you see in the above pic when draining the pan. No need to pull the plate to check underneath at all. After doing my initial oil change, installed both Fumoto valve and skid plate----the small inserts that cover the access points to both filter and pan are the only things I've removed since (couldn't be easier except for that damn hard-for-me-to see-dipstick :)).
Deleted User 412290
Nice setup!
I've just had a number of rear main seal leaks, etc. on previous vehicles, so I want to remove the whole plate at oil change intervals to give things a once over.
Looks easy peasy the way you have it set up though!
Dipstick is impossible lol
Wife bought my 24 TRD
Anthony
Aberdeen Wa
Fumoto long value all the way. An option you might consider is, RCI. I've got a full set of aluminum RCI skids, and the access points for oil changes everywhere needed are plenty adequate for my large hands, and the fitment is amazing.
Something to think about. A bonus is they mate up with almost every FULL LENGTH, after market bumpers being produced at this point.
JohnSadler
JohnSadler
Moore, OK
What’s the model number on the Fumoto you chose?
nurp42
TRD PreRunner
'24 PreRunner
^^^^ I’ve got this one. Pretty sure they’ve now got an updated version (F133N) that’s larger and drains faster. Been beyond satisfied w/ mine and if it drained any faster it’d reduce my quality beer drinking in the driveway with the truck time too much (and who’d want that :unsure:).
VB Taco
Virginia Beach, Virginia
John, your question could not have been better timed. I too am in the search for the best skid to get.
So far I'm leaning to the millercat. The access holes have me sold. Already have the Formoto valve waiting to be installed.
I'm willing to wait until they come back in stock.
JohnSadler
JohnSadler
Moore, OK
I’m glad you’re finding the thread useful! I think I’m going to go with RCI but that could change.
Cariboo Ryan
Quesnel, British Columbia
2020 GMC Sierra AT4
Where are you seeing these prices? When I go to autoparts.toyota.com the Land Cruiser front skid plate is $425.
RutsyBucket
Hunter
Carlsbad, CA
2025 Terra Off Road
take the part number and throw it in google. You'll get different prices from different dealers, they all choose to participate in whatever promos or not, so you'll see quite difference prices depending on season or coupon.
There is also a one time use 25% off code that can stack with seasonal sales (at some dealers.) There's probably a memorial day sale coming up end of May.
Deleted User 412290
