Lexland Rear Recovery Points 2.0 Installed
tacomasport1121
Robert
2024 Tacoma Sport
Super easy install overall. The hardest part was removing the plastic frame caps without breaking them — a plastic trim removal tool definitely helped. Really happy with how this mod turned out and the added functionality/looks it brings to the Tacoma.
2024 Tacoma Lexland Rear Recovery Points 2.0 Installed IMG_2943
2024 Tacoma Lexland Rear Recovery Points 2.0 Installed IMG_2940
Ruckus
2025 Tacoma SR5
Did your truck come with reinforcement sleeves welded to the frame where you bolted the recovery points?
If I remember correctly, models with the plugs in the frame do not have the sleeves necessary to torque these down. Doing so without the sleeves can bend your frame. I had to add aftermarket sleeves to my SR5 when I installed my rear recovery points.
Cornfed Suspension sells the sleeves for a reasonable cost - https://cornfedsuspension.com/4th-gen-tacoma-recoverypoints/
Disregard if you already have the collars.
tacomasport1121
Robert
2024 Tacoma Sport
Good question. I will have to check. The need for the reinforcers is for when you install or if you use them in a recovery situation?
Ruckus
2025 Tacoma SR5
You need the sleeves to be able to torque the bolts to spec without damaging your frame. The bolts need to be torqued to spec in order to use them for any recovery situation.
If you're simply looking for aesthetics, then don't torque the bolts too high and just know to never pull from those.
It's fairly cheap insurance to buy the sleeves and install them in the event you ever need to use the recovery points.
If these are from Lexland, I can guarantee that they're for aesthetic use only, not real world application.
Ruckus
2025 Tacoma SR5
I mean I tend to agree with you, but also, it's just a hunk of forged steel. I suppose they could be using a mild steel.
TX-MD
marvin
AR
Tacoma, 4Runner
‘25 SR5 long bed here. My potential mounting points look like this. Assume it indicates I have the collars?
2024 Tacoma Lexland Rear Recovery Points 2.0 Installed IMG_4492
2024 Tacoma Lexland Rear Recovery Points 2.0 Installed IMG_4494
tacomasport1121
Robert
2024 Tacoma Sport
I would say that you are good to go! Don’t forget discount code RM20 to save some money if you’re going to get the Lexland Recovery points.
