Electrical uses/limits for Aux Switches/Inverter
TacoTime
Forester
There is interesting info in the user manual for those interested in using Aux Switches and Inverter for camper outfitting or other uses.
Owners manual
Aux Switches: Page 488
  • Aux only operates with ignition on and may turn off with low 12v battery voltage.
  • Connections are plugs with waterproof caps that are removed to be used with a Toyota accessary wiring harness pigtail (assumed parts Dept.)
  • Circuits: Diagram on page 489
    • AUX1 - 15amps
    • AUX2 - 10amps
    • AUX3 - 5amps
  • Diagram shows that AUX1-3 have wired all three circuits stubbed to these locations.
    • Under hood driver side front.
    • Driver seat kick panel.
  • There is also a 20amp wire run from under hood driver side front to the bed by the tailgate. This wire run looks like it can be plugged into the under hood driver side front to power. It also looks like if one wants to do a second battery under hood or other, they could use this wire run for that separate from AUX control. This wire run has a 20amp fuse under rear seat.
Inverter: Page 483
  • There seems to be some operational discrepancies between YouTube videos on the 400W features and the manual. Someone will have to test once they have a truck. It is notable that if start/stop is engaged (assuming non-hybrid) then the power will cut if the engine stops. (Expected)
Nixamantacoma
United States
2022 Ford Bronco Outerbanks
Thanks for sharing this. I was looking for this information a few days ago. The salesman at the dealership did not know the answer to the location of the aux wiring.
StreeTaco
2024 Tacoma TrailHunter
FYI in case you missed it.
As stated in manual…
2024 Tacoma Electrical uses/limits for Aux Switches/Inverter 1705714293054
M1KL83
Tacoma TRD OR 6MT
Any updates on these pre-wired aux switches? Following to see how creative minds put these to good use.
I was nearly set on Offroad 6mt but recently found out Sport + 6mt in Canada includes the 3 aux switches. Another tic in the Sport + column.
Thanks for digging up all that valuable information..dealerships had next to no idea.
Jojoedarte
Joseph
New Mexico, USA
2018 Honda Accord
I’m with you on trying to see what they could actually be used for. I just installed ditch lights from RC and realized these switches are pretty limiting because they are only set up for such low amperage. I didn’t look like they will support the 30 amp light bar requirements.
svaughn76
Plano, TX
2024 Bronze Oxide Toyota Tacoma TRD Off Road
I would've liked to have the Aux switches pre installed on my truck but I only took an allocation which didn't have one. Anyone know how I can obtain the cables and aux switches so I can install them in the factory locations. I looked on the accessories and parts page but was unable to locate the part number.
CuriousTaco
Seattle
TRD OR Base
In the same boat. I was looking around and noticed a few capped connectors in the engine bay and the rear. I couldn't tell if they were for the aux switches. The fuses for the aux switches aren't present where they live in the driver's side engine bay. I think it may be easier to add aftermarket aux switches and run all the wiring DIY instead of trying to integrate the factory equipment.
Bjl0719
Brandon
West Virginia
So I took apart the panel where the AUX switches would be if you had it (which I don’t) and I noticed these to plugs going to blank switches, does anyone know what they are for? Of if they go to one of the caped plugs which ones they go to.
2024 Tacoma Electrical uses/limits for Aux Switches/Inverter IMG_6814
2024 Tacoma Electrical uses/limits for Aux Switches/Inverter IMG_6815
CuriousTaco
Seattle
TRD OR Base
This question has come up a few times. Myself and others have also discovered these connectors and aren't sure what they go to. Ultimately someone who has access to both an upgrade/premium package truck and base truck would need to validate if terminated connectors in the base truck are the same as the factory aux upgrade switches.
Even if they are the same, there could be other hardware components required to make them functional. When I was looking in the engine bay at the driver side fuse panel it seemed like both the wiring and fuses were missing for the factory aux switches. I don't think anyone has been compelled enough to open up the factory wiring looms and trace the wires to figure out what is what...
MHG
Mark
Long Island
2025 TRD Offroad
I am hearing the 2025’s added a 4th switch and increased the amperage.
TFOUTS
Timothy
Northwest Florida
24 Tacoma Trailhunter, 26 4Runner TRD PREM, 03 Tacoma TRD OR, 03 Sequoia SR5
This is true of the 2025 Trailhunter model. My 2024 Trailhunter has 3 Aux's. There are 4 ports on the body, 2 under the hood, one in the cab, driver's side kit plate and one in the rear on the frame. I am trying to find a 4th switch to install in the panel but so far, no success
MHG
Mark
Long Island
2025 TRD Offroad
Turns out the 4th switch is NOT on the lower trims (OR down).
TFOUTS
Timothy
Northwest Florida
Like anything else you only get what you pay for. Attached is my 2024 left switch panel. The 2025 panel is identical except there is now a 4th aux switch to the right where mine in blank
2024 Tacoma Electrical uses/limits for Aux Switches/Inverter IMG_4941
