diablo2112
Southwest USA
In the great dechroming of my Limited, I found a spectacular local deal on a set of 2023 Tundra takeoffs ($500 for wheels/tires; prior owner had bought these for a 3G Tacoma and found they didn't fit). The big question: do they fit our 4G? It's surprisingly hard to find definitive information on this question. After a bit of research, it appeared they would probably fit, but I couldn't find anything here on Tacoma4G from anyone that took the plunge.
Given the price, I figured it was no-lose on my end. Just mounted them up this morning, and the fit is identical. Same offset, same bore, same BCD. Stock lug nuts tightened the same number of turns (about 8-9). As far as I can tell, they also have the same offsets and are positioned in the wheel wells same as stock.
So, 2022+ Tundra wheels fit our 4Gs. These are 20" Tundra wheels, and rolling diameter is about 1" larger. Will give a 2mph error in speed at 65, but I can live with that. Personally, I think the dechromed Limited is better looking.
2024 Tacoma CONFIRMED: 2022+ Tundra wheels DO fit the 2024+ Tacoma 4th Gen IMG_2280.JPG
2024 Tacoma CONFIRMED: 2022+ Tundra wheels DO fit the 2024+ Tacoma 4th Gen IMG_2282.JPG
2024 Tacoma CONFIRMED: 2022+ Tundra wheels DO fit the 2024+ Tacoma 4th Gen IMG_2283.JPG
2024 Tacoma CONFIRMED: 2022+ Tundra wheels DO fit the 2024+ Tacoma 4th Gen IMG_2285.JPG
Deleted User 1813921
Guest
This is so cool! And as a total bonus there is tons of them for sale super cheap! I think you just showed me my spring summer daily driver set up. Will put off road tires on 17” switch out as needed for terrain and run this 17” off roads fall winter.
Daveintb
Tampa
That’s a good find , I was searching for wheels also and can’t find much with the stock offset or close to it. Thanks.
I see you still have the Crome exh tip, that’s an easy removal if you wish ( 1 bolt )
JED
Southern Tier NY
2015 Tacoma TRD Sport
And now it’s custom. Love the wheels.
Dansflhti
Nova Scotia
They actually look pretty darn good on there.
evlfred
Monte
Idaho
how do the guys putting 37's on correct the speedo?
evlfred
Monte
Idaho
I really thing the limited should have come with 20's
BillyJoeJimBob
Idaho
Nothing
Have you checked your speed with GPS? My tacoma read a few MPG below actual. Going up 1 inch on tires might make your speedo read just right
oxi
Pete
Wisconsin
2024 TRD Sport 6MT
Sweet, I picked up a pair of Tundra wheels 18" and mounted 265/70 KO2's on them for my full size spares. Might be slight wider but overall height is about the same.
Discount tires gave me a plastic spacer and new lug nuts for the system.
2024 Tacoma CONFIRMED: 2022+ Tundra wheels DO fit the 2024+ Tacoma 4th Gen thumbnail_20240424_162926
xraided
Albert
San diego
what are the specs of the tires on them?? Im looking for tundra wheels myself!
I remember seeing instructions in the owner's manual for recalibrating the speedometer based on wheel changes.
Daveintb
Tampa
265/60R20
I’m also going to do this with my Limited, I bought a set of 20” Tundra wheels and I’m waiting for Tire Rack to deliver my tires. I’ve noticed these Tundra wheels are about 10 pounds heavier each , have you noticed any acceleration loss ?
