2024 Tacoma sport has issues with front tire mud flap! My black Sport has debris (stone) damage to the rear quarter panel.
Russell Bertch
Russell
Otsego
My new Black Tacoma sport with only 5000 miles on it has stone damage to the rear quarter panel - about 25 chips on both sides.
ridetime
Oklahoma
Yes it is a known problem. That ridiculous factory "mud flap" offers virtually no protection. I fixed the problem with a set of Rokblokz rally mud flaps and the HD2 running boards from rough country.
Mini2nut
I really like those RC running boards.
The 4th Gen OEM splash guards have definitely shrunk from the Gen 3.
Yeah - that is a good choice. The tires on my Pro are only about 1/2 covered by the factory flaps.
I am adding RCI sliders, which will provide some protection and also getting PPF on the rear fenders. If that is not enough I will get better flaps like @ridetime has.
tkrum015
Ted
Olympia
PPF the front and rear fenders. If you zoom in on rear you can see the film line behind the gas fill door.
Dataman
Randall
2001 1st Gen Toyota Tacoma
Where did you get that step board? My Sport Taco came with Predator steps and I want to replace them.
batman900
Oklahoma
24 Tacoma OR
I second the idea of adding PPF to that rear area. I ordered some clear 3M from Amazon, a small squeegee and an exacto knife. Measure, cut, spray a water/soap mixture and apply. Took me about 3-4 tries for each side but it turned out great & only cost me like $30. It’s pretty dang invisible so even if your cut is wonky nobody will see it. Just don’t get blue fuzz stuck under it from a blue microfiber cloth like I did a couple times…. Wanted to burn that towel…
Flyfish007
NJ
2024 TRD Sport
Do you have a link for the 3M?
batman900
Oklahoma
24 Tacoma OR
Sure, this is the one someone else recommended and it worked great.
Edit, hold on forums are being weird and it isn't attaching. Remove the space between www. and .com
https://www. amazon .com/dp/B004VG88MQ?ref=ppx_yo2ov_dt_b_fed_asin_title
Flyfish007
NJ
2024 TRD Sport
Got it thanks!
