Looking to swap Trailhunter steel skids for UHMW plastic
trailhunger
2024 TH
Looking for a plastic skid for the Trailhunter front engine - for winter driving. I don’t 4x4 trail in the winter where I live it’s all pavement & mountain driving. Snow chunks & gravel deflection is the game half the year. I considered swapping all skids to 5052 1/4” aluminum but I can’t square the price when I already have it kitted in steel. My TH is 6’ bed, so naturally I’m handicapping the extreme off-roading anyway due breakover angle. The goal is to shed some weight on this rig 6-8 months out of the year. How good is that powder coat on the TH steel skids…. Rock rails probably get pulled during the winter too, maybe add a step for the lady.
A smooth plastic, not the felt-like deflector stuff on the OR. Anyone know of any shops that would have this for the TH? It’s a weird ask, but shedding ~350lbs half the year is tempting. Would rather just leave the steel engine skid on than drive it naked but the rest of the trail kit can sit in the garage until spring
PotatoTRD
Denver
2024 trd pro
I don’t know of anyone making UHMW skid plates at the moment, I have been trying to convince RCI to make some! But if I’m not mistaken the skids and sliders for the trailhunter are super lightweight and you might not be really achieving that much by removing them, if I remember right that front skid is only 26lbs and the trans is similar. You would maybe be saving ~120lbs at the most if you removed everything
trailhunger
trailhunger
2024 TH
…You would maybe be saving ~120lbs at the most if you removed everything
Each rock slider is what ~100lbs? Or gross over exaggeration from people selling theirs?
PotatoTRD
Denver
2024 trd pro
I mean I personally haven’t weighed them but I can almost guarantee they are not 100lbs each. My aftermarket RCI sliders are much more robust and heavy for slider standards and are around 70 lbs each
trailhunger
trailhunger
2024 TH
Yea wouldn’t surprise me they’re 60lbs and fellas haven’t lifted a 100lb dumbbell in years.
End of month when I have time I’ll remove one of these TH sliders and get it hooked up to the scale
OR has the Smooth plastic skids. I’ll be replacing mine when the budget allows? Not sure what models have the felt skids? But they are not on mine. My RCI sliders are 75lbs per side with top plates. I’d bet the Toyota sliders are around 60lbs..
soupy1234
Show Low AZ
2024 Tacoma OR Long Bed
I don't know about the stock ones but the ones from NYTOP are 74 lbs. each. The other aftermarket ones are similar (except for one maker that has aluminum ones).
hemlockz
‘24 TRD Offroad 6MT
Stock rails are 56 lbs each. So I’m not following, how does a steel skid plate have any effect on winter driving? Isn’t more weight better in snow?
Sner
My OR premium has felt like skids plates (if you can call them that in felt) I too would also like to see some in plastic, something stronger than the OE ones without having to spend a fortune on metal ones. I’m not doing rock climbing with the truck but would like something better than felt for the winter, I can see the OE ones deteriorating pretty quickly over a couple of winters. Years ago it’s what came on many Japanese 4X4’s, good quality plastic skid plates. I’d also love to see some cost effective plastic skid plates - yet to find any, hoping this post leads me to some. :)
I don't off-road, but I prefer the comfort of having a shield on the engine bay and transmission for road debris and grime.
The Limited Hybrid came with the crossbar but with the felt behind the air dam.
I've order both the forward and secondary plastic covers to swap things out.
Including a full bolt set (yeah, I know you know need 2-4 more, but when I order parts I order all the supporting fasteners as a CYA, just how I do things) plus the "whistle plugs" (I'll call them), it was under $250.
trailhunger
trailhunger
2024 TH
Traction is key. The truck is plenty heavy already. Weight distribution/ evenly spread across all contact points. The protection plates are the lowest points to the ground so yes it doesn’t hurt having them on in the winter but I’m after fuel economy. If I’m doing a trip from front range Colorado to the Wasatch in February truck will only see pavement, 98% of it dry sanded cleared roads.
I’ve seen Rivians in ditches. They’re heavy a f, batteries distributed to the lowest point in the frame. Traction & winter driving skills far more important than weight. A super light WRX w/3 Peak Nokians full send, thing sticks to the road like no other vehicle out there
But hearing how the actual weight of the TH skid plates & sliders is much lower than people have estimated probably will leave it stock this winter and wait for UHMW options to hit the market
beungood
Jack
Plymouth,Mass
2001 Toyota 4Runner Limited
Could always go to a Plastic Sheeting Company and have sheets cut in the shape of your current skid plates and then drill out the holes after laying out the originals on your new UHMW sheets. I did this with one of my snow plows.
soupy1234
Show Low AZ
OR should have composite ones (they call them engine covers, not skid plates).
Airborne
Upstate,NewYork
UGH…why did you buy this model tacoma ….?? , weight, swapping, c.mon. So many guys have bought these trucks trailhunters, pros. To why ??? Cruise the mall parking lot or home depot….ffs.
Sner
You are correct. Whatever they are made of they are flimsy not as well built as they could be. I‘d Like something better without having to go to aluminum or steel.
