Status
Not open for further replies.
Will-Stillen
Costa Mesa, CA
stillen.com
2008 Toyota Tacoma
Hey Guys,
We finally released our trucontrol tuner for the Tacoma! All plug and play for easy hp!
Check the site out for more details.
If you want to save some money send me a message on here!
https://stillen.com/collections/ele...ntrol-by-stillen-inline-power-module-tc201003
024+ Toyota Tacoma TruControl by STILLEN Inline Power Module - TC201003
Now with 14 Day Satisfaction Guarantee - Test it in your own vehicle completely risk free. Custom files available when purchasing other Stillen performance products.
Upgrade your 2024 or 2025 Toyota Tacoma 2.4L Turbocharged 4-cylinder with the TruControl by STILLEN Inline Power Module – the easiest and most effective way to unlock hidden performance from your factory ECU. Whether you're driving a base model or a top-tier i-FORCE MAX hybrid, this plug-and-play tuner is engineered to work seamlessly with all trims.
Thanks to precise tuning of critical engine parameters and increased boost pressure, you can expect substantial gains in power and torque across the entire rev range. Installation is quick and simple — no cutting, splicing, or soldering required. You’ll be enjoying better throttle response and significantly improved acceleration in about 15 minutes.
Even better? The TruControl Power Module is designed to be warranty-friendly. Just remove it before dealer service visits and drive worry-free.
Performance Gains You Can Feel
  • +29 Horsepower at the wheels
  • +48 lb-ft of Torque at the wheels
  • Gains at the engine:
    • +35 HP
    • +58 lb-ft TQ
These are real, tested gains that dramatically improve drivability without compromising reliability or safety.
Key Features & Benefits:
  • Up to +35 HP / +58 TQ increase*
  • Works with all 2024-2025 Tacoma trims, including i-FORCE MAX hybrid
  • Plug-and-play installation — no tools, splicing, or wiring needed
  • Does not alter the factory ECU
  • Bluetooth integration with free tuning app
  • Preloaded with up to 7 custom driving maps (Eco, Sport, Race)
  • Reversible for factory warranty with no trace left behind
  • 14-Day Satisfaction Guarantee
  • Custom tuning files available for additional STILLEN upgrades (intake, exhaust, etc.)
  • Not for sale in California
Why Choose TruControl by STILLEN?
Unlike generic tuning modules or irreversible flash tunes, TruControl gives you real performance gains in a safe, flexible, and easily reversible format. Whether you're off-roading, towing, or daily driving, this module can be adapted to your lifestyle by our expert tuners.
If you’re not completely satisfied within 14 days of delivery, simply return it for a full refund — no questions asked.
ejosesa
Joses
los angeles
tacoma off road 4x4
Interesting. I like that you can customize as opposed to OTT’s. I wonder how they compare. Are shift points altered as well?
Will-Stillen
Will-Stillen
Costa Mesa, CA
stillen.com
2008 Toyota Tacoma
It does not interface directly with the transmission. Increasing the HP and TQ will slightly alter and improve dead spots but if you want full on customization then you would need a full ecu flash.
Tacocho
Alex
Portland, OR
Hey Guys,
    • +35 HP
    • +58 lb-ft TQ
How much boost pressure is the engine producing after installing the module? How much psi more than stock? Are you guys able to determine that the engine can safely sustain the increased pressure?
Will-Stillen
Will-Stillen
Costa Mesa, CA
stillen.com
2008 Toyota Tacoma
Numbers are bumped only a few pounds of boost. The tuner would know the exact as each customer will vary.
We only use about 90% of the cars potential so staying under 10% is well within the safety parameters. Also, since this is a piggy back and not a ECU flash the factory parameters are still in place as a second safety placement.
We're confident in our tuning and would not be releasing something that would be dangerous to customers motors.
Knute
2025 Off-Road Prem. 6MT, 89 Bronco 5MT, 69 MGB 4MT OD, 13 Outback 6MT
o Does it work with an Off-Road 6sp. Manual?
o Does it require premium fuel?
o How much does it cost?
Will-Stillen
Will-Stillen
Costa Mesa, CA
stillen.com
2008 Toyota Tacoma
Yes, will work with your 6sp manual.
If you're going to run the hotter maps we recommend using premium fuel. Regular fuel mixed with adding hp/tq does not work well.
These are on sale right now for $649.00
Wife bought my 24 TRD
Anthony
Aberdeen Wa
Hey Guys,
    • +35 HP
    • +58 lb-ft TQ
What makes you different than the pedal commander?
And what makes you a better option than getting a tune from overland tune.
Will-Stillen
Will-Stillen
Costa Mesa, CA
stillen.com
2008 Toyota Tacoma
Pedal Commander is just for throttle response. Our trucontrol is a piggyback tuner which will provide more HP and TQ.
A customer may choose ours over OTT because ours is a piggyback so no ECU flashing. If you go in for warranty work remove our harness and the dealer can't see if anything was ever there VS flashing the ECU they will deny warranty. Ultimately that's up to the dealer though.
Ours is user friendly and plug and play.
lane.bax
Lane
MT
2025 Tacoma OffRoad
Your claim about preserving the warranty by simply removing the device sounds cute on paper, but let’s be honest, advising ppl to remove it to avoid detection is just disingenuous. The second a dealer finds out you’ve done that it’s a clear indicator you’re being deceptive and essentially making an attempt to defraud the dealer and Toyota.
Being told to “unplug it so they don’t know” raises more concern than confidence and frankly should be a red-flag.
SMH
Will-Stillen
Will-Stillen
Costa Mesa, CA
stillen.com
2008 Toyota Tacoma
SMH
We actually have a few dealers who are tossing these on vehicles on their lot.
Some dealers honestly don't even care that they are on. If you are not comfortable with running one check with your dealer first as its their call if they warrant any work or not.
Regardless of your stance on tune/chip companies, I think it should be mentioned that the Magnuson Moss Warranty Act still applies and any warranty issues have to be proven to be caused by either device/tune.
If you read the OTT threads, OTT claims it's not detectable by Toyota. They have a Toyota Master Tech on staff and say that Toyota, nor the dealers, are looking for tunes; Techstream does not detect it. Take that for what it's worth. I'm not advocating for or against OTT or Stillen; I'm just going by the posts that suggest the OTT tune is very popular.
Status
