TrailAdventurer
JT
Canton, MI
Oddly enough, for everything Toyota got right with the Trailhunter, one thing they really could’ve done better was the choice of tire. My personal philosophy on avoiding punctures is simple: keep enough rubber between the sharp stuff and the tire carcass. On our Jeep, I replaced the tires when they had about 8mm of tread left—roughly halfway through their life. The Trailhunter’s OEM tires start with just 8mm of tread. That’s not something I’d trust in serious backcountry terrain.
After running through eight sets of KO and KO2s over the years on different rigs, I decided to try something new for the Jeep: the Mickey Thompson Baja Boss A/T. Loved them so much, I grabbed a set for Riddick—our Tacoma. Went with a 34" tire, LT275/70R18, mounted on the OEM rims. Very happy with the setup. The tread lines up nicely with the wheel flares, and no trimming or mods were needed.
I’ve run wider tires before—like 35x12.5s—but this time I wanted something narrower. At just under 10" of tread width and with around 2,000 miles on them, the MTs are doing great so far.
A couple caveats: First, these have a more aggressive tread for an A/T, so they’re noticeably louder than the KO2s at highway speeds. If OEM is a 0 and “I ditched them last week” is a 10, I’d rate them a 4 or 5. Manageable, but present. Also, these will need rotating every 3–5K miles to keep wear even.
Second, even though Riddick weighs about the same as our Wrangler—around 5,400 lbs—the narrower 34x10s don’t corner quite the same. There's some scrubbing and slight understeer when pushing hard through turns. Part of that is still getting used to the platform, but it’s clear the aggressive cornering grip isn’t quite at the level of a 35x12.5.
Off-road, in the dirt and light mud we’ve hit so far, the MTs are a noticeable step up from the KO2s—not a massive difference, but definitely there. If I had to do it again, I’m probably 55/45 in favor of trying the KO3s instead. For our needs, the extra off-road grip is nice, but the truth is, 90% of the truck’s miles are on pavement—and the KOs never let me down.
I really do like these tires—but ask me again in a few thousand miles. ?
2024 Tacoma Trailhunter - Replaced the OEM Rim Protectors (Tires) w/ Mickey Thompson Baja Boss A/T LT275/70R18 (34") MT Poke on Trailhunter (1).JPG
2024 Tacoma Trailhunter - Replaced the OEM Rim Protectors (Tires) w/ Mickey Thompson Baja Boss A/T LT275/70R18 (34") Trailhunter - 34x10.JPG
mikeymtbs
Atlanta, GA
24 TRD Offroad Premium
Just put some 275/70-18s on as well and they measured out to 33.2” vs 34”. Just my experience. Looks good!
Brent@ANParts
Brent
www.autonationparts.com
Ford Bronco
Nice, I love me some rim protectors. It's a strangely satisfying feeling after scraping the curb, slightly panicking, then going out to see you just rubbed the tire.
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
I stopped reading when I learned your trucks name is Riddick. That’s awesome! Brilliant name. Badass name and it fits.
Off-road, in the dirt and light mud we’ve hit so far, the MTs are a noticeable step up from the KO2s—not a massive difference, but definitely there. If I had to do it again, I’m probably 65/45 in favor of trying the KO3s instead. For our needs, the extra off-road grip is nice, but the truth is, 90% of the truck’s miles are on pavement—and the KOs never let me down.
Fuck yeah
Mrknowitall
SE MI
20 Silverado, 22 XV
275/70R18 is a completely standard half-ton size and should corner just fine. Have you played with the inflation at all?
This is a very heavy 3 ply tire so it may just be par for the course in terms of driving characteristics - I would use the online tools available to determine PSI. I believe the correct pressure would be 36 or 37 psi if I recall correctly but I can look it up later. Higher PSI = rougher ride but better handling / cornering.
TrailAdventurer
TrailAdventurer
JT
Canton, MI
By the way this is a 33” tire — either 33.2” or 33.4”
Correct. 33.4" Wanted something a tad larger than stock w/o getting into trimming and what-have-you. More importantly, wanted more rubber.
TrailAdventurer
TrailAdventurer
JT
Canton, MI
I've experimented with a range of pressures to evaluate comfort, handling, and full tread-width contact. At 30 PSI, the outer ¾ inch of the tread doesn’t make contact with the pavement, which can lead to premature center wear.
Since tire pressure gauges can vary—my two differ by about 2.5 PSI—I chose one and stuck with it throughout my testing to stay consistent. Running empty, I'm finding 27 PSI is working well for me now. Since I rotate aggressive tires every 3,000 miles, I'm not particularly worried about abnormal wear patterns.
I'm hesitant to publish a specific PSI recommendation because it’s subjective and can lead to endless debate, much like choosing the "best" oil. Pressure depends heavily on the vehicle and intended use, which is why manufacturers don't offer a one-size-fits-all PSI. That said, sharing my experience might still be helpful for others going through their own trials.
Over the years, I've learned that dialing in the right pressure requires experimentation. I'm satisfied with my current setup. As for dry-pavement grip, it's simply a tradeoff—tires with large tread blocks and high void ratios just don’t grip as well as less aggressive tires.
TacoTrails
2026 Toyota Tacoma Trailhunter, 2024 Subaru Outback Wilderness, 2021 BMW R1250GS
Awesome! Very interested in doing the same.
@TrailAdventurer did you need to remove the crash plate to prevent rubbing?
Did you replace the spare? If so, how well do these fit underneath?
TrailAdventurer
TrailAdventurer
JT
Canton, MI
I only went up 1" in tire diameter, to a 34". I didn't need to remove the crash plate, which was one of the main reasons I chose 34s over 35s.
Yes, I also replaced the spare and kept the standard black spare wheel. It fits underneath without any issues, including raising and lowering it.
The key is that going from 33s to 34s only increases the radius by 1/2". Combined with sticking to a narrower tire, I've had zero clearance issues.
I've also taken them off-road, including situations with significant suspension articulation, and haven't experienced any rubbing whatsoever.
Bottom line: The 34s have been a perfect fit, with no modifications needed and no clearance issues, either on-road or off-road.
