Cali Raised LED
Jake
Fort Worth, Texas
4th Gen Tacoma
Tailgate Theft Protector for 2024+ Toyota Tacoma
https://caliraisedled.com/products/tailgate-theft-protector-for-2024-toyota-tacoma
The 2024 Tacoma comes with a lot of upgrades, but one thing hasn’t changed: the tailgate can still be removed in seconds if you know how. Thieves target this all the time, especially in parking lots and driveways. If you’ve got a brand-new tailgate with color-matched panels, a camera, or assist hardware, it’s worth protecting. This stainless steel anti-theft bracket is a simple mod that adds serious peace of mind.
Why it Works:
This bracket mounts to the passenger side of your tailgate hinge, preventing the tailgate from being lifted off without tools. Once installed, it blends in behind the tailgate when shut, offering stealth protection with no visible hardware.
Key Features:
  • Fits 2024+ Toyota Tacoma
  • Made from corrosion-resistant stainless steel
  • Installs on passenger side tailgate hinge
  • Blocks the removal slot when tailgate is closed
  • Quick install using basic tools – no drilling required
  • Protects against grab-and-go tailgate theft
Install Notes:
Takes about 5 minutes with a socket wrench. Just remove the bolt on the hinge, position the bracket, and reinstall. Make sure the tailgate opens and closes cleanly before torquing it down.
FAQ:
Does this work with tailgate assist or camera wiring?
Yes, it doesn’t interfere with the assist strut or camera harness. It’s mounted at the hinge, not inside the gate itself.
Will it rust?
No – it’s made from stainless steel, so it holds up to road salt, rain, and snow without corroding.
For anyone who parks in public or just wants to lock down their investment, this is a no-brainer upgrade. You can grab the 2024 Tacoma tailgate anti-theft bracket directly here https://caliraisedled.com/products/tailgate-theft-protector-for-2024-toyota-tacoma
2024 Tacoma Protect Your 2024 Tacoma Tailgate Anti-Theft Bracket Tailgate Theft Protection White 01 (1)
2024 Tacoma Protect Your 2024 Tacoma Tailgate Anti-Theft Bracket tacoma theft protector lifestyl
Canufixit
Canu
New England
2025 sr DC 4x
Why it Works:
Key Features:
Install Notes:
FAQ:
Will it rust?
Dumb Question .... I assume it comes with the anti theft screw and driver bit ?? Is the Security screw all the same ? i.e. one removal tool fits all ?? Thanks
gofastdan
I installed this a couple of days ago and, yes, it comes with a security screw and the bit. You just remove an existing bolt (10mm socket if I recall?) and replace it with the new screw. Nice piece for the price. The edges are pretty sharp but once it's installed you're never going to touch the edges anyway...
Looks way nicer than a hose clamp and the security screw provides a bit more protection!
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
Ordered one. Might be a dumb concern since I'm not going to take it off but, in the photo above it looks like its rubbing the paint and causing rust on the truck. I might have to add a thin foam gasket behind it to prevent that.
rijc99
Are these more or at least equally secure as the hose clamp style band with lock? I know they look better but there is nothing locking it right? I ordered one to check out either way.
Canufixit
Canu
New England
2025 sr DC 4x
Well, I have a Hose clamp style. It's there because the Tailgates are so attractive and somewhat ways easy for snatch and run - At least it slows them down. But now feel that as long as there is an easily obtainable "removal" driver or key - it's the best I'll do for now ...
Canufixit
Canu
New England
2025 sr DC 4x
Mightyquinn
Andy
Fayetteville,NC
2025 TRD Pro Ice Cap/Cockpit Red
It says on their website that this doesn't work with power lift gate is this true or an error? Is this even needed with a power locking tailgate?
