17" wheels on Hybrid Tacomas
zbennett
Zack
SC
2024 Tacoma TRD OR Hybrid
I remember reading somewhere that hybrid Tacomas have a larger brake package than other Tacomas.
I am curious if there is anyone out there who has tried to put 17" wheels on their hybrid tacoma and run into clearance issues regarding the brake calipers.
I have seen several examples of people putting 17" wheels on a hybrid tacoma without issue but just want to make sure.
I am currently looking at the RRW RR5-H wheel in a 17x8.5 +25
If yall have a hybrid on 17s, Id love to see em
oldskoolarcher
Nick
Central PA
'24 4G Taco, '24 Defender, '15 WK2
I have 17"x8.5 Method +25mm Wheels on my 2024 TRD OR Hybrid. Currently has 285/70/17, but will be swapping them out for 285/75/17 tomorrow.
No clearance issues.
Briosauce
Michigan
2024 Tacoma TRD Off Road Hybrid
I'm considering this route. Would be great to see a few pics when you're done.
Deleted member 8077
Guest
Do you have any pictures of your setup?
daneg6
Daniel
2026 Tacoma Trailhunter, 2025 Lexus Gx550
2024 Tacoma 17" wheels on Hybrid Tacomas IMG_5328
17x8.5 +0 tires are 285/75R17 with no issues.
BLtheP
TX
Hybrids and TRDs have the exact same front brakes and in the rear the hybrid steps up to a 17” minimum wheel size brake setup from the 16” minimum that the SR/SR5/TRDs have. 17’s officials will fit perfectly fine just like they do on other trims since 17” is the maximum wheel diameter required for a Tacoma brake setup.
tacosinnataco
Sep
Bay Area, CA
Got any shots of the poke? I've been considering these wheels since '24 LOL. I really like how they look. Also, these look like toyo tires - have you considered 34x10.5r17 toyos? I'm assuming these are load C, which is heavier than the load D tire I mentioned. I'm trying to be mindful of weight as MPGs already suck. Just by swapping tires, I'm adding 15ish LBS per wheel.
