jackvz
Jack
richmond
2025 Tacoma Trd Pro
I would be worried about a truck coming from the other direction haha
306trd
Saskatchewan
21 Escape Hybrid/26 TRD OR+
If I may, where abouts is this? My wife is from BC and we're looking forward to taking on some FSRs when we can get back
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
I am curious as to whether you changed your tires and/or wheels for those conditions. Any chance you’re using the stock tires?
What inflation (psi) were you running in the snow?
Thanks for letting me pick your brain. I have not yet had the truck in the snow and it is the same configuration as yours. I live just north of Southern California (Central Coast).
TrailhunterBC
TrailhunterBC
Tacoma Trailhunter
This is Upper Squamish Valley... from main FSR you take any of the roads that go up in the mountains
TrailhunterBC
TrailhunterBC
Tacoma Trailhunter
I changed the tires to Mickey Thompson Baja Boss AT. I have few other offroad vehicles and I use them on all my offroaders. I find them extremly good in any condition especially snow. They have snow flake rating as well. I was at 15 PSI here but on the snow I would go sometimes to 8-10 PSI if i have to.
Backcountry1
jason
kelowna bc
2025 toyota tacoma trailhunter
I’m curious if you changed the stock size of your mickey thompson tires? Did you go up or stay the same size? Also, are you running an E load rating or a C?
Thanks
TrailhunterBC
TrailhunterBC
Tacoma Trailhunter
Thanks
I went up, from 265 to 285 and load rating is E.
TrailhunterBC
TrailhunterBC
Tacoma Trailhunter
My load is on the order of 2000-3000 so would likely get Load C….sounds prudent to you?
Appreciate the insight.
Load C may be ok for the weight you have but I would go with E just for toughness and trail abuse. It's one thing driving on paved roads and totally another when rocks start gouging your side walls. Load E has tougher side walls and everything else. I think load C is like 6 ply while E is 10 ply.
TrailAdventurer
JT
Canton, MI
I changed the tires to Mickey Thompson Baja Boss AT... I find them extremly good in any condition especially snow. They have snow flake rating as well. I was at 15 PSI here but on the snow I would go sometimes to 8-10 PSI if i have to.
I put the same tire, 275/70, on our TH. Have only been in snow with them twice now. Performed much better than I expected. After decades of running KO/KO2s on my vehicles, the Mickey's are at least as good. Was time to try something different.
Thanks for sharing the video.
