portalhunter
Bob
Sold the GFC earlier this summer and replaced it with a DiamondBack Switchback 2.0. Posting what I have learned since 4th gen info on this cover is still thin, and the old threads mostly describe the original Switchback, which the 2.0 replaced with a ground-up redesign (toolless clamp jaws, lower profile, lighter panels).
Why DiamondBack
Researching hard folding covers taught me that almost everything you would cross-shop is one company: RealTruck owns BAK, Extang, Gator, Retrax, Roll-N-Lock, TruXedo, and UnderCover. The classic BAKFlip vs Retrax debate is one conglomerate arguing with itself. DiamondBack is one of the last independents, building to order in Pennsylvania. At $1,599 shipped it costs a few hundred more than a BAKFlip MX4, so the question was whether the hardware justifies it.
2024 Tacoma Diamondback Switchback 2.0 folding bed cover: early review rear-moody
The hardware
Flip a panel over and you can inspect the construction directly: .080" 3003 aluminum plate, 5356 TIG welds, stainless hinges, structural studs bracing the underside. Nothing glued or foam-cored. The weld beads where the clamp-jaw mounts meet the panel look like something off a fabricated bumper, not a bed accessory.
2024 Tacoma Diamondback Switchback 2.0 folding bed cover: early review welds-clamp-jaw
Over the aluminum goes a spray-on coat that DiamondBack says is the same bedliner material Toyota sprays into factory beds. It reads exactly like factory bedliner in hand, and it does two jobs in Arizona: fine dust rinses off without chalking, and the textured surface stays touchable after a day in full summer sun. The GFC panels used to get scorching here; these do not.
2024 Tacoma Diamondback Switchback 2.0 folding bed cover: early review badge-texture
No keyed lock, on purpose
There is no lock cylinder anywhere on this cover, which bothered me until I thought it through. Two 7-inch clamp-jaw handles seize the bed rails from inside, so once the tail panel is clamped, the only way into the bed is through the tailgate. Lock the tailgate and everything is sealed. The exposed topside hinge screws spin in place against nylon lock-nuts underneath, so there is no quiet way in.
2024 Tacoma Diamondback Switchback 2.0 folding bed cover: early review hinge-detail
Weather
Sealing is an EPDM compression gasket around each panel perimeter with formed gutters carrying water off to the sides. Several monsoon storms parked outside plus over 3,000 miles including genuinely heavy rain, and nothing significant has made it past the gasket. Camera cases come home clean, which is my real test.
2024 Tacoma Diamondback Switchback 2.0 folding bed cover: early review gasket-edge
Daily use
Closed and clamped it carries 400 lb on top and holds 600 lb standing, so you can stand on it to load or strap cargo to the four included anchor plates. Two loaded San Diego runs so far: hard cases and a fullsize spare flat on the floor, duffels on top, cover closed over everything. When the load went above the rails, the panels folded against the cab and the bed went back to being an open box in under a minute. One limit from the manual: you cannot drive with only the tail panel folded, since the straps secure a full stack at the cab end. It is all the way closed or all the way folded on the move.
2024 Tacoma Diamondback Switchback 2.0 folding bed cover: early review panels-folded
The one issue
During our first shock tuning run the cover shifted at speed. My read is the mechanism fastening the cab side needed more tension than I had it at. Nothing broke and it retensions by hand, but check your clamps before a fast dirt day. I will report back if it moves again after retensioning.
Trade-offs coming from a GFC
Standing height and side hatches are gone, and rack tracks would block the fold, so roof loads are off the table permanently. Packing order becomes a discipline on a 6-foot bed: trip gear at the front, daily-grab stuff at the tailgate. For how this truck actually gets used, covered secure storage every day beat standing height a few weekends a year.
Disclosure: DiamondBack sent this cover at no charge with no conditions on what I write. Full review with all photos: https://truck.bdigitalmedia.io/blog/diamondback-switchback-tacoma-review/
Happy to answer questions, especially from anyone cross-shopping this against the HD or a BAKFlip.
TacoBirdinNW
2025 DCLB SR5
Looks pretty sweet! I've only had my Topo for the summer, but I'd be lying if I said that weighing the pros/cons of driving around with a camper topper on my daily driver hasn't crossed my mind. And that's in the summer! There's about a 2% chance I will camp from October through April up here 😂
ridetime
Oklahoma
Why DiamondBack
The hardware
Weather
Daily use
The one issue
Nice cover. Diamondback stepped up the cover game on all the BAK Flip style options. I am curious about your HD comparison. To me they are pretty different use cases and the HD is significantly more expensive. Nice review!
Kodachrome
2005 Tacoma TRD Offroad, 2026 Tacoma Trailhunter
Thanks for the write up, I figure this is the right thing to have to secure gear when I don't have the pop-up, slide-in camper on. I assume that if left in the folded but lashed position that the cover it self could be prone to theft so best to keep it unfolded and locked.
portalhunter
portalhunter
Bob
Thanks for the write up, I figure this is the right thing to have to secure gear when I don't have the pop-up, slide-in camper on. I assume that if left in the unfolded but lashed position that the cover it self could be prone to theft?
if someone wanted to steal it in that position they could. they would need to twist the mechanism that latches to the bed rail and remove the safety latches from the back side. you could definitely add something more heavy duty if you’re concerned with that scenario
Kodachrome
I'm not really concerned, just thinking the process through. I have ordered it and look forward to getting it in a few weeks. I did see one review in which the user had concerns with it coming close to the rear window when open, so when open and lashed, how much clearance do you figure you have and at 74lbs (?) is it cumbersome to remove if a one man show?
portalhunter
portalhunter
Bob
very easy, just did it myself in 115 degree heat 🤙
Cordoc
Gaston
Tacoma Trailhunter 2024
Why DiamondBack
The hardware
Weather
Daily use
The one issue
Very nice post.
I actually had to pay for mine!
I am a small guy and had no problem installing it by myself. I needed a bit of help putting it on the bed, but if I did it, anyone can do it.
Mine is a 6-foot bed. The parts fit perfectly, the locks are high quality, and they make stealing harder but if they really want to get in they will.
I have put 13000 miles on the truck with them on and have had zero problems; also no water has gotten in.
I dont think you can but a better cover.
Kodachrome
So I get mine on Tuesday, I am hearing some with the power tailgates are having issues with the tailgate not operating correctly with the covers on.
Did you have any issues with that and either way, do you have any tips in that regard?
OminousSkitter
Alaska
Does the new version interfere at all with the compressor / power ports? I read some previous reviews that mentioned the clamps got in the way of those, but that might have been the original switchback not 2.0.
Kodachrome
Interesting and had not thought of that. I would think overall it would be fine since I would be opening the first panel to get the hose to the front wheels anyway?
OminousSkitter
Alaska
All depends on what you're trying to do. There's a lot more you can use a compressor for than just airing up your front wheels. Unlatching isn't the end of the world if it is required.
This post (#16) shows what I am asking about, but that is from 2024 (so not the 2.0).
portalhunter
portalhunter
Bob
yeah you have to tension the clamps properly. also i think adding some silicon grease to the seal will help with less friction as well, once you get dust in there it’s noticeably worse.
portalhunter
portalhunter
Bob
yeah no issues getting to the compressor at all. or the AC outlet. i do have a 128L ROAM box right there that i have to move out of the way to latch it closed though
Kodachrome
Thanks. In looking at the top of my tailgate, I was thinking of adding a slick vinyl tape over the grooved parts to make the seal transition smoother. Dust intrusion sounds logical and will be a scheduled maintenance item, like regular door seal cleaning.
