4Runner 5th Gen TRD wheels and TPWS
Want-a-taco
2024 Tacoma OR 6MT
So, I got some 17" wheels from a 5th gen 4Runner and they have TPMS sensors (or TPWS like Toyota says, not sure why they felt the need to flip the M upside down), but I can't get them programmed. I followed the procedure in the manual, it shows that it will discover them while driving. I've gone on 3 different drives of 1 hour each and still detected.
I'm wondering if they are compatible at all? 5th Gen 4 Runner is like 3rd Gen Tacoma.
Anybody had luck with these wheels?
2024 Tacoma 4Runner 5th Gen TRD wheels and TPWS 1775495119347-p3
WhiskeyTallwood
Matt
It's likely that they are NOT compatible. When I had my Wrangler, I bought OEM wheels from a guy who's Jeep was one year newer than mine and the TPMS on his wheels was incompatible with my Wrangler, even though they were the same generation...
aaronbudgell
aaron
hvgb
2025 tacoma off road
I purchased a set of winter tires from Toyota with Toyota sensors in them . Changed the tires out went into my gauge cluster and select set 2, drove approx 1/4km tires registered and never had an issue with them.
KDubZ
Kody
Hawaii
25 Tacoma TRD Off Road Premium, 19 4Runner SR5
If it’s the screw on style (Silver nut next to valve cap) then it’s not compatible. Toyota switched to a new style of TPMS around 2021-2022 and those ones have the rubber valve stem and the sensor bolts to the back of the valve stem. Those ones seem to work off a different code then the previous ones. To my knowledge you still need a TPMS tool to program sensors to the truck if they are sensors that were not previously paired to the truck.
goin2drt
KY
They are not compatible. 2017 4Runner is a Pacific T3 and the new Tacomas are a T6 or Denso 550-0106.
BTW the valve stem material has NOTHING to do with compatibility. They make the same protocol in both rubber and metal many times.
