lfe
South Lake Tahoe, CA
2024 TRD PRO
SO much nicer than the CATuned bracket. With 37s and airing down to 10 psi on a regular basis, I wasn't so adverse to the added cost for the brushless twin compressor.
One thing a lot of folks overlook when considering an engine bay mounted compressor bracket is that it competes with an ideal location for a winch control module relocation bracket:
2024 Tacoma Air Compressor Build - compressor choices and building into TRD OR bed IMG_3313
socotaco
socotaco
NorCal
26 TRD OR
Here is my setup. I went with the ARB Dual Brushless and added the Apex reel to make things easier.
Your setup looks super neat!
Is the mounting for the Apex reel their universal vertical mount painted black? And are you feeding air to the reel directly through the side of the bed as there is no visible hose - very trick.
Rubenc87
Ruben
2025 TRD PRO
Here is the mounting plate (painted). 2nd Pic shows where the air line is run from ARB to CRS.
2024 Tacoma Air Compressor Build - compressor choices and building into TRD OR bed IMG_4797
2024 Tacoma Air Compressor Build - compressor choices and building into TRD OR bed IMG_4851
socotaco
socotaco
NorCal
26 TRD OR
Ah, that helps a lot, thanks. Super nice install.
