Perry
2024 TRD OR Hybrid
I was finally able to get to the install of my Rough Country dual compressor. I installed on bed between bed and body. The only hiccup I had was I couldn't get the Aux1 switch to work on it. I had power to the plug in the back, but couldn't get it to tune compressor on. Gave up and just used the switch that came with it and it works great. probably a better spot for the switch anyway.
SonoranSurvivalist
Arizona
I'd like to see more pics on this one! Definitely something I want to do too since right now my solution is keeping a compressor in the truck bed.
rougesix29
Brian
Oregon
2024 Toyota Tacoma sr5
Did it come with the box and door or was it separate? I have a ARB twin with 1.5 gallon tank I’m getting ready to install. I’m same location drivers side. Well done.
ChesterCopperpot
Perry
2024 TRD OR Hybrid
Here is a pic of it from underneath, you can get a better idea of where it is located. I used rubber washers on both sides. There is a very specific spot where it fits and I missed on my first shot. On the Hybrid there is a rubber grommet underneath right near rear driver side door that goes right into battery area under backseat. Didn't even have to pull any plastic trim. I think this is basically where the compressor is on the Trailhunter. I can get more pics tonight if anyone wants to see anything specific.
2024 Tacoma Air Compressor Installed IMG_9245
ChesterCopperpot
Perry
2024 TRD OR Hybrid
I put the switch and quick connect in the data box in the bed that came with my truck. Not sure if it is part of the package or not. I have a hybrid offroad with upgrade package.
Nicholas28Molinary
Nicholas
Hammond la
I would love more pictures of this tonight?
MHG
Mark
Long Island
2025 TRD Offroad
Nice, thanks for sharing. What’s the second wire fire? Future component install?
You gonna use inline fuses or you adding a fuse block by the battery?
ChesterCopperpot
Perry
2024 TRD OR Hybrid
It is a dual compressor so each pump is powered independently.
nxr
Ny
this is great. having a hard time picturing where you installed the compressor exactly. is that under truck by bed?
ChesterCopperpot
Perry
2024 TRD OR Hybrid
It is installed on the side of the bed, just under the box where the quick connect is installed that you can see in the pics. It is a pretty cheap and clean set-up, I probably spent $400 total and it is a much faster compressor than the OEM compressor that comes with the TH.
Rubenc87
Ruben
2025 TRD PRO
What connections (90* elbow) did you use for the air chuck in the data box? Thanks
Rubenc87
Ruben
2025 TRD PRO
Thanks for the links. This is what I have been wanting to do. I would rather do aftermarket than OEM. OEM would have to stay in vehicle permanently vs move to another vehicle But the way yours is mounted gives the user easy access without having to open the hood. You said that you missed then mounting originally and had to redo. What caused the miscue? Thanks Trying to get it on the first try.
2024 Tacoma Air Compressor Installed IMG_4369 2
2024 Tacoma Air Compressor Installed IMG_4375 2
2024 Tacoma Air Compressor Installed IMG_4374 2
