CaliRaised front skid recovery point incompatibility
cyranodabum
Orange County, CA
2024 TRD OR Hybrid
I installed the front skid plate from CaliRaised last week. It involves removing the front recovery points (I have the Toyota ones) and reinstalling them afterward. However, because of the angle on the skid plate, I can’t reinstall my recovery points anymore. There’s not enough room for them to mount flush against the skid plate. Has anyone else encountered a problem like this with CaliRaised (or any other brand skid)?
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
cyranodabum
Orange County, CA
2024 TRD OR Hybrid
I have a hybrid, so I have the cross member and was able to bolt the skid plate to the cross member. Also, the bolts are technically long enough to attach the recovery points to the frame. It's just that because of the skid plate design, there's no way to get them to sit flat like they are supposed to, so they are not secure anymore and not really usable for a recovery now.
lauren01
Lauren
Ventura, CA USA
Completely sucks. I wonder if the OR recovery points can be attached like the Trailhunter recovery points, or if they are totally different. I think the answer is…argh. Different.
Rising Sun
Tom
North Georgia USA
2025 Toyota Tacoma Trailhunter
I think I'd ask Cali raised what recovery points they had in mind when they designed that skid. It sucks that they don't mention any conflict with OEM parts on their site. They say that they are 100% bolt on. Lauren01 above may be right that they work with the non-PRO or Trailhunter OEM black tie down points.
lauren01
Lauren
Ventura, CA USA
A workaround might be to notch the skid plate at the recovery point. I’d request CaliRaised to refund part of the price paid or send something else of use at no charge. I’d be so annoyed…mod equipment has annoyed me from hours of extra work, so I get how you may feel.
Cabby30
CA
2024 DCLB TRD OR
I would put the recovery hooks between the skid and frame and use a set of 2x spacers on each side to mount the skid. So, frame > tow hooks > spacer > skid plate > bolt.
I don't know what the spacer height would be or if the length of current bolt would be sufficient. Just brainstorming here.
cyranodabum
Orange County, CA
2024 TRD OR Hybrid
CaliRaised confirmed that the aluminum skid plate has different angles up front than the steel skid plate, and it's not compatible with the Toyota front recovery points as is. They've now updated their product page with that disclaimer.
Thankfully, I have the front crossmember, so the skid plate doesn't need those extra attachment points under the recovery bolts. Their suggestion was to trim them off. I appreciate that they gave me a generous partial refund (in lieu of sending it back and them sending me a modified one, which they also offered).
Looks fine after all is said and done.
