RESOLVED: Creaking sound when turning at slow speeds. NEED HELP IDENTIFYING ISSUE.
Dbldwn11
Tom
Voorhees NJ
See video above. I have a 2025 Tacoma TRD Off-Road Hybrid with a Westcott Designs perch collar lift, Method wheels, and 285/75R18 Nitto E-rated tires. I honestly can’t remember if the noise was there before the lift, wheels, and tires were installed. It only happens when turning the steering wheel at low speeds (under 10–15 mph), usually when pulling in or out of parking spots or making slow turns.
Is this creaking sound normal? If not, does anyone have an idea what it could be?
UPDATE: 7/30
Just got back from Toyota. The issue was the lower control arm bolts/fasteners and the steering rack bolts/fasteners needed to be re torqued/tightened. So glad they were able to figure it out. Crossing my fingers the noise doesn’t come back!
taco4th
Ibrahim
Oregon
tacoma
I had that problem I fix it by doing an alignment and making sure your camber and caster bolts are really tight or it will make the sound I don’t know if this will fix yours or get under the car while someone turns the wheel and pinpoint the origin of the noise.
SAR Taco
Seattle, Washington
2024 Trailhunter
I had a somewhat similar creaking sound at low speeds. I took it in for Toyota to diagnose, and they mentioned that it was somehow related to loose bolts on the skid plate. They also mentioned this is something that has seen with other Tacoma's with skid plates. As soon as they reattached the skid plate, the nose went away.
Dbldwn11
Tom
Voorhees NJ
Do you have a skid plate?
I do. I removed it prior to making this video and it still made the same noise. I have an appointment with Toyota Wednesday so hopefully they can figure it out. I’m wondering if it has anything to do with the pre collar lift and heavier wheels and tires?
Dbldwn11
Tom
Voorhees NJ
Thanks. Hopefully Toyota can figure it out.
Dbldwn11
Tom
Voorhees NJ
I also have a skid plate. I removed it and it’s still making the same noise. So weird. Hoping Toyota can figure it out.
TacoMoFo
Los Angeles
2025 Tacoma Offroad
Interesting. I have the exact same sound on my truck and I also have aftermarket skids and suspension. My Toyota dealership said it was coming from my suspension and that they couldn’t do anything about it since it’s not OEM. I’ve also noticed that when I go offroading the sound disappears but will return once the truck cools off. This sound is frustrating given that my truck is only 7 months old.
Dbldwn11
Tom
Voorhees NJ
Wonderful. I had a feeling they wouldn’t be able to do anything since it’s not OEM. Mine sounds like it’s the tie rods and only happens when I turn the steering wheel. So frustrating.
turnermier
oregon
25 trdor hybrid
Had the exact same issue, alignment bolts were not torqued correctly which caused the metal collar inside the bushing to slip.
Torque both cam nuts to 207 Ft lb or 280Nm
MAKE SURE VEHICLE IS ON THE GROUND OR YOUR LOWER CONTROL ARM BUSHING COULD GET DAMAGED.
Les Schwab had them at 100...
2024 Tacoma RESOLVED: Creaking sound when turning at slow speeds. NEED HELP IDENTIFYING ISSUE. download
Dbldwn11
Tom
Voorhees NJ
Dbldwn11
Tom
Voorhees NJ
Dbldwn11
Tom
Voorhees NJ
Dbldwn11
Tom
Voorhees NJ
Dbldwn11
Tom
Voorhees NJ
