Thank you!There should be a 5 pin inside you're over counsel that's used for the factory dash cam. That's how I did it with the Donger Pro
I bought the Viofo wire kit. I used the add-a-fuse and ran the cable down over to the passenger footwell fuse box. Works great. Parking mode works and the big plastic footwell covers the fuse box just fine without needing to smaller black fuse cover.Just got my Hybrid TRD sport a few weeks ago. And got the VIOFO A229 pro 2 channel. I bought and installed the Dongar pro but it wont allow for parking mode. Bummer. So now I’m looking to hardwire the dash cam but there’s not a lot of room which you guys know. (I read the whole forum.) Is it safe to just take the harness through the firewall and tap into the fuse box on the drivers side under the hood? Is there a better option. I literally just got my windows tinted and I didn’t use the electrostatic film so if I replace the cameras I’ll be replacing at least one window tint. Thoughts and ideas are needed. If I use the one in the engine compartment do I dril a small enough hole to allow my wires to come through where the fuse cover meets the fuse box ? Is that safe? Also can I just add a secondary fuse box is that a thing? Thanks
I ran into the same issue. Same camera, same-ish truck. (24 trd or) I have the hardwire kit that I'll use instead. Can you tell me which sets of fuses you tapped for remote and continuous power?I bought the Viofo wire kit. I used the add-a-fuse and ran the cable down over to the passenger footwell fuse box. Works great. Parking mode works and the big plastic footwell covers the fuse box just fine without needing to smaller black fuse cover.
Here you go. The little black cover can’t go on but the big black plastic cover still does and no way to hit the fuse box with your feet with it on. It all works great.I ran into the same issue. Same camera, same-ish truck. (24 trd or) I have the hardwire kit that I'll use instead. Can you tell me which sets of fuses you tapped for remote and continuous power?
*Also, I've read add a fuse won't allow the cover to snap back on. How did you get around this?
Any idea when the 5pin adapter is restocking? Been waiting for a while now.FYI, here are the official steps on accessing the 5-pin rooftop 'option' connector.. it is a tool-less process but it would be wise to use a flat & wide pry tool, if your fingers are too fat.
Alternatively, you can access the 10-pin mirror connector (tutorial coming soon) which we also have a product for. The 5-pin connector is present in all 2024+ Tacomas and was placed to help upsell you on the OEM Toyota dashcam. The 10-pin is absent in the models without autodimming mirrors (i.e. SR5 without premium package). We have a slight preference for using the 10-pin connector since our current 10-pin dashcam adapter is designed to be windshield mountable whereas the 5-pin version is not. Our new parking mode adapter is modular and will include both 5-pin and 10-pin harnesses in one package.
Any reputed manufacturers dash cam power supply (70mai, Vantrue, Redtiger, Viofo etc) can be used with interior fuse box, under the glove box on the passenger side. Often free with the dashcam with the fuse tap connectors.So reading over this thread and poking around on Donger's site, it looks like I'll need the DCA-5A adapter for my base SR. I don't have an auto dimming mirror. It seems like I'll be looking for connection inside the overhead console and not near the mirror.
Am I on the right path?
Yes, the fuse box is an option. But I want to utilize the overhead console/mirror area for a cleaner, similar install. I appreciate your help though.Any reputed manufacturers dash cam power supply (70mai, Vantrue, Redtiger, Viofo etc) can be used with interior fuse box, under the glove box on the passenger side. Often free with the dashcam with the fuse tap connectors.
There is harness available for that with 12v supply to use with a dash cam power supply though I am not sure if all models have this unused connector. I guess easier to remove the overhead console and check.Yes, the fuse box is an option. But I want to utilize the overhead console/mirror area for a cleaner, similar install. I appreciate your help though.
