Does the snorkel present a problem for ditch lights on a Trailhunter?
SmokyMtnTaco
Rob
East TN
2025 Toyota Tacoma Trailhunter, 2018 Toyota Tacoma TRD Sport
It does and I have a solution on installing these 5 inch LED Driving Pods with Ditch Light Side Shooters, what I'm calling hulked out ditch lights!
src=""
2025 Tacoma Trailhunter Ditch Light Problem SOLVED!
airxmarshall
Marshall
Utah
2024 Tacoma Trailhunter
I put some rough country 3" lights on, the clearance is extremely close. I had to angle them correctly to fit, but they work! The plug and play with the aux buttons was super easy, I just had to do some surgery on the wiring harness since I have DRLs in the ditch lights. I used aux 1 and 3 to separate the DRL and lights so I can operate them separately and together.
TFOUTS
Timothy
Northwest Florida
I installed Rigid mounts and white(marine) Rigid pods, SPV harness connected to aux2. To open the hood I have to turn the right pod facing the left pod for clearance at the back of the pod when close to the snorkel with the hood up. I carry a small box wrench in the truck to loosen and tighten the pod to turn.
Mine is too close to open my hood. My plan is to find a 2” rectangular bracket to get the ditch light about 1” toward driver. I think it’ll work.
2024 Tacoma Does the snorkel present a problem for ditch lights on a Trailhunter? IMG_7796
I
2024 Tacoma Does the snorkel present a problem for ditch lights on a Trailhunter? IMG_7797
Vidman
Mass
I have cali raised brackets and Baja designs squadron pros and they fit great. No issues opening the hood. You need the correct offset on your brackets
