Front bumper recommendation - need help/input
Catfish
Adrian
Stockton Ca
4th Gen Underground
You haven't researched aftermarket bumpers or looked at there install guides at all have you. You easily know if the sensors will work before even ordering.
I ran the adaptive cruise control all the way to Moab from Sacramento. Lmao. I don’t know what his problem is but he clearly doesn’t have a clue about what R&D is. This isn’t something that was simply just slapped on. This was thought out, then executed. Sheesh.
TFOUTS
Timothy
Northwest Florida
Lol. Thanks. I posted them just for you. ??
Hey Moundman, here it is. Just got back last night. Had planned on camping there but the wind was about 50mph with higher gusts. Had to go into Hanksville.
Moundman
Statesville, NC
2024 Honda Accord Hybrid / 2024 Trailhunter
Nice, Great pics. I loved it out there. I got up early in the morning to take this shot at the place you r last photo was.
TFOUTS
Timothy
Northwest Florida
When we went in 2022 in our 1st gen, we flew the drone. It was too windy to fly last week.
Pappy
Jon
Intermountain West
All I will say is a Toyota tech told me if you remove the grille you need to disconnect the battery first, before unplugging the grille plugs. Otherwise, your run the risk of loosing the sonar sensor and it will need to be reprogrammed.
And before you say it ... this isn't something I heard. I'm speaking from experience. I learned this the hard way. My truck was two days at the dealer while they tried to figure out how to reset the sonar. As far as I'm concerned every single company that sells aftermarket front bumpers needs to say this up front in their install directions. DISCONNECT THE F'N BATTERY BEFORE REMOVING THE GRILLE.
My C4 front bumper.
Cali Raised LED
Jake
Fort Worth, Texas
caliraisedled.com
4th Gen Tacoma
Hi all,
Im planning to get a front bumper for my truck soon. Any recommendations?
Hey! If you're still in the market for a front bumper, check out the Cali Raised Stealth Bumper for the 2024+ Tacoma ($499.99): https://caliraisedled.com/products/stealth-bumper-for-2024-tacoma
It's a low-profile bumper that keeps things tight to the body. It fits a 32" single- or dual-row light bar, is winch-ready with our separate winch tray, has dual 3/4" recovery points, and keeps Toyota Safety Sense and the front sensors working. It bolts to the factory mounting points with slight trimming of the factory bumper. A bolt-on bull bar is available if you want to build it out over time. Trailhunter owners: it fits only with the factory Trailhunter skid plates removed.
Pappy
Jon
Intermountain West
My only comment is before you purchase look at the install instructions. Pay attention to how the bumper attaches and if you think it would survive a winch pull. Some of these bumpers I would not trust to survive a winch extraction.
I went with C4.
Catfish
Adrian
Stockton Ca
4th Gen Underground
My C4 front bumper.
K
TrailAdventurer
JT
Canton, MI
Relentless Fabrication. ***Mic Drop***
Looks nice. Unfortunately, in Michigan, things like that look nice for about 3 years, tops. If it's not a garage queen. I've a front bumper from WARN, and sliders and rear bumper/carrier from LOD, on my Wrangler. After 5 years, everything needs to be pulled, sand blasted, and re-coated. The rust is killer.
Catfish
Adrian
Stockton Ca
4th Gen Underground
Good thing it’s in the garage. ?
TrailAdventurer
JT
Canton, MI
I didn't want to spend a fortune on a bumper so I went with the DV8 Offroad bumper...
Prior vehicle, had DV8 bumper. Came down off a ledge; gently as I could. Bent easily. Something I've done multiple times since w/another brand. Hope they've upped their game for you. If you find yourself having to put it to serious use, let us know how it performs.
Nacho TacoMan
Paul
2025 Tacoma Limited. 2018 BMW X5 335d
Hey! If you're still in the market for a front bumper, check out the Cali Raised Stealth Bumper for the 2024+ Tacoma:
? Stealth Bumper – 2024 Tacoma
It’s a low-profile hybrid-style bumper that keeps things tight to the body—perfect if you want added protection without going full-blown bulky. Designed to fit most 20" or 32" light bars, winch-ready, and bolt-on install with no cutting required.
Plus, you can add side recovery points and a bull bar if you want to build it out over time. Clean, functional, and trail-tested.
Your website clearly states that cutting is required. Did you guys change something?
Moundman
Statesville, NC
Thanks will do. I've only hit it once in Utah on the very bottom and it was good. I'll def keep that in mind though.
Cali Raised LED
Jake
Fort Worth, Texas
caliraisedled.com
4th Gen Tacoma
