Great Dash Mount Solution
bsquaredMTB
Ben
El Paso, TX
I had been going back and forth on a drill or no drill solution for a dash mount system. After looking at several options, I settled on the rubigrid dash mount with universal phone device holder from bulletpoint mounting solutions. One of the main reasons i went this route is because it kept the panel behind the 14" inch screen. The no drill option (ICS) was really nice but I didn't want that area behind the screen exposed to the elements.
The install instructions on this mounting system were really good and they came with the templates to do all the drilling on the panel behind the screen. I did worry about about drilling out holes but I figured if things went horribly wrong I could always order another panel.
Long story, short, this is a GREAT mounting system and I'm really happy with it!
2024 Tacoma Great Dash Mount Solution 20260707_100011
2024 Tacoma Great Dash Mount Solution 20260707_095957
2024 Tacoma Great Dash Mount Solution 20260707_095734
2024 Tacoma Great Dash Mount Solution 20260707_111835
2024 Tacoma Great Dash Mount Solution 20260707_144956_3a57da6d
Will721
Will
Quad Cities
2025 TRD OR
It looks smaller than the one I've been eyeing from Caliraised. I like it!
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
Nice setup. Have the same Rubigrid setup from BP. Great stuff. Just bought the radio handset hook to install when I put in a GMRS radio. We’ve got a bunch of other attachments and reconfigure according to trip needs. Fun cool gear.
zekesview
Zeke
Walnut Creek, Ca
www.zekesview.com
2025 Toyota Tacoma TDR Pro
I dig it. I bought that also but have to sell it.
I have one from CaliRaised and tossed the OEM trim piece. I don’t want to buy that piece again.
I did keep the arms and I also got the handle mount for my radio - which is awesome. Moved from B Ball Mounts to all 20mm mounts which I like a lot more. Smaller and just as strong.
Too late to return the BulletPoint version so I’ll be selling that.
2024 Tacoma Great Dash Mount Solution IMG_3533
2024 Tacoma Great Dash Mount Solution IMG_3532
2024 Tacoma Great Dash Mount Solution IMG_3531
2024 Tacoma Great Dash Mount Solution IMG_3530
Wife bought my 24 TRD
Anthony
Aberdeen Wa
Something to think about? Nice. Can you tell me what lighting setup you have, I like the look. TY
zekesview
Zeke
Walnut Creek, Ca
www.zekesview.com
bsquaredMTB
bsquaredMTB
Ben
El Paso, TX
I have that same lighting. The install is pretty easy but you should be careful not to break the clips. I broke a few of mine but the dealership was nice enough to replace them at a minimal cost. Other than that, their install video is really detailed and straightforward. They have the map lights and the dome light in the rear of the cab. One really nice feature is you can toggle between red and REALLY bright white whenever you need some serious lighting. I have the map and dome lights and normally keep mine on red.
