- Joined
- Dec 12, 2025
- Threads
- 54
- Messages
- 727
- Reaction score
- 585
- Location
- Washington
- Vehicle(s)
- 2025 DCLB SR5
First you need the skid plate (PT228-60242). And then you'll need to order a crossmember if you have a lower trim (SR, SR5, Sport, or the shiney one). I chose the RCI crossmember.
Install the front crossmember as shown below and then tighten it down underneath your front tow hooks to 75#. Loosely install the the two bolts that correspond to the larger mounting point cutouts on the skid so you can hang the plate while installing and tightening the rest of the bolts. Install the remaining 4 bolts. The 4 rear bolts are then tightened to 27# while RCI says the aftermarket crossmember bolts should be hand tightened.
And that's it! Enjoying being awesome.
Landcruiser skid plate and RCI crossmember
Front crossmember installed beneath tow hooks torqued to 75#
Loosely install 2 mounting bolts to hold the skid plate
Skid plate can now hang while you install the remaining bolts
Tighten all 6 bolts. Rear 4 to 27#, front RCI crossmember bolts handtight
Now you are super cool.
