Let's Talk About Dedicated Winter Tires
Are you running dedicated winter tires? If so, I'd love to hear what your favorite winter tire is and which tires you have tried.
I'm still shopping. Still haven't made a decision. My top 3 are Nokian LT3, Nokian R5, and Blizzak LT. They each have completely different designs, and not much information about how they actually perform.
I thought the Nokian LT3 (non-studded) were the ones, but then I noticed that they have less siping than the others. So they potentially have less traction on packed snow and ice? I don't know that for sure, but it makes sense. And ice traction is my main reason for getting winter tires. So back to the drawing board.
My wife has blizzaks in her RAV4. They are impressive.
Well it is his most current test for winter tires. He’s got countless other videos that are very good. It will be a good place for the OP to start? Maybe someone has time to go the them all and post the most relevant.
fredygump
Darren
Minnesota
2026 Tacoma SR5, 2016 VW GTI
:cwl: When the weather over runs our ego it's good to have options:blush:
For the record, in my little story, I knew I was in trouble while I was still on the entrance ramp. I just didn't know how much time I would have to think about it!
Your point about tire chains is a pretty neat solution. Then I don't need a tire that is best for everything.
Also, it provides a good reason to NOT get the biggest tire possible. Because I don't want chains tearing out my fender liners. My truck is equipped with 30.5" tires, and I am leaning toward 31.5" for snow tires. 265/65R18
I live in a cold snowy environment, conditions change constantly. I have Nokian Outpost NAT’s on year around and they have never let me down. You must be careful with chains. The only time I use them (once) was deep wet nasty snow, and I had no choice. I no longer own a set.
IDontWorkForTheWaterCo
2026 Tacoma SR
I live in a cold snowy environment, conditions change constantly. I have Nokian NAT’s on year around and they have never let me down. You must be careful with chains. The only time I use them (once) was deep wet nasty snow, and I had no choice. I no longer own a set.
They can definitely tear some stuff up if they aren't installed correctly or they fail.
Dirt
Greg
Eastern OR
Interested - how do those hold up in the summer on the hot highways you get just like we do? Do you put many miles on a set over a year's period? We take the Blizzak's off because the tire tread wears off so quickly in the hot summer months.
OminousSkitter
Alaska
Nokian Outpost nAT's are a road-focused all-season, all-terrain tire. Pretty well reviewed -- especially in winter -- if you aren't doing serious off-roading. I strongly considered them, but every tire shop near me had to special order them.
oxi
Pete
Wisconsin
2024 TRD Sport 6MT
I run KO2's year-round when I drove my 2010 SR5, 2016 SR and have them on my 2024 TRD Sport.
The problem I run into of late, is I simply park my truck for the winter.
My Corolla SE I had in the past and now my Camry AWD fit the bill in just about all conditions. If more than 6 inches on the ground, I have to make a decision at 3 to 4am, but so far my truck has been parked all winter.
Both Corolla and Camry run Blizzak's, WS-90's for their softer compounds to handle extreme low temps. Traction is fantastic. 4wd trucks and crossovers slow me down on the roads, and sometimes I can pass them on snowy roads.
Corolla had factory 18's and I dropped down to a steel 15 with the WS-90's to get more rubber and ground clearance. Camry comes with 18's and I drop down to steel 16 with the WS-90's.
It works, but I do not run them year-round. They perform at temps near freezing or lower.
Pics are stock vs steel with WS-90's.
2024 Tacoma Let's Talk About Dedicated Winter Tires thumbnail_1000000601
2024 Tacoma Let's Talk About Dedicated Winter Tires thumbnail_1000000692
2024 Tacoma Let's Talk About Dedicated Winter Tires 05c683a7-2919-49a4-bc06-76394361c313
2024 Tacoma Let's Talk About Dedicated Winter Tires thumbnail_20251031_141132
bitflogger
WI
I have had dedicated winter 3PMSF tires and now have had different models of the year round category of 3PMSF tires. From that I'm going forward with the year-round type 3PMSF rated. This is because the winter season still means a lot of driving on pavement where the dedicated winter 3PMSF tires have some disadvantages.
LoganLeafs19
Logan
Newfoundland, Canada
2025 Tacoma TRD Sport+
I have Nokian Hakkapeliitta R5 SUV on mine and they're fantastic for the heavy wet snow we get in Newfoundland, Canada. Initially I had Firestone Winterforce 2UV from the dealer and hated them but I didn't have much choice when I picked the truck up in December 2025. They were constantly losing traction even with some weight in the bed over the rear axle.
fredygump
Darren
Minnesota
Can you comment about the R5's traction and acceleration on packed snow and ice? Tyre Review channel's review says it performs a bit worse than other tires on ice, but significantly out performs everything else in dry conditions.
I'm wondering if you can actuall tell when driving? It is probably splitting hairs, but I'm intersted since you have actual experience with this tire!
LoganLeafs19
Logan
I can't really say what the ice traction is like on the road, the Atlantic coast of NL doesn't get a ton of freezing rain and the government is very aggressive on the road salt. That being said we had quite a bad berm built up at the end of our driveway that got quite icy. The winterforce's couldn't get over it even in 4Lo, meanwhile the R5's rolled right over it like nothing was there in 2Hi.
As for packed snow, occasionally I had to put it in 4Hi to get moving, but after that no issues with going back to 2Hi. The performance is comparable to Michelin X-Ice I've used on my previous vehicles.
The Blizzaks are on from November to April.
