Loading...
Sancheesy
Shawn
Ontario
Interesting...
Yotota
SW WA
24 TRD
To answer your question: yes, but there are caveats.
If you read through the other thread (that you linked to) there's a discussion going on about it.
Yotota
SW WA
24 TRD
the caveat is that it’s greyed out after the first time you apply your settings.
I am asking if there is a way around this.
Negative, that's not a caveat. That's a sign that you can't access the function again. ?
(Just giving you some flak)
The caveats are that you need to recalibrate the Circumference Monitoring System in order to access the Diagnostic Menu camera adjustment again, or do everything through Global Techstream Plus.
The Circumference Monitoring System is being discussed in the other thread. I'm waiting to hear what another menu has to offer for those with the greyed out camera button.
Coming from an IT guy (software), have you tried turning it on and off again??
In other words, have you tried doing it after unhooking the battery for a few minutes? Wonder if it's something that is stored in memory or not.
Yotota
SW WA
24 TRD
I appreciate you explaining this.
So what exactly is the Circumference Monitoring System? Is that a fancy term for the 360 camera? If so, and I understand this correctly, to adjust the front grill cam, you will need to re-adjust all the cameras and only get 1 shot at this?
That's what we're trying to figure out.
Originally, the Circumference Monitoring System was just the Sonar parking sensors. Now it also includes the cameras (for things like Pedestrian detection), which is why the systems are linked.
Yotota
SW WA
24 TRD
This is totally worth a shot!
MHG
Mark
Long Island
2025 TRD Offroad
I find it annoying that the computer stitches together the horizontal plane and correct for distortion so the ground looks like a satellite shot, but no attempt is being made to correct distortion on the vertical plane so parked cars an either side of your vehicle look huge and distorted. This throws off your brain when parking making you think your closer to the vehicle that the overhead shot shows
