Loading...
JED
Southern Tier NY
2015 Tacoma TRD Sport
Bump. Looking to order tonight and hoping someone can point me in the right direction
I have method 703 wheels on my truck and ordered the lugs through them. This is what they provided. They provide 11 thread contact.
Can’t help with TPMS as I used the OEM from the truck.
2024 Tacoma Loading... IMG_7184
goin2drt
KY
SpartanCaptain
PA
2024 TRD Sport
These are technically not correct.
SpartanCaptain
PA
2024 TRD Sport
Can you elaborate?
The tacoma technically requires Extended thread or ET Lug nuts. These are extended thread but the wrong kind. These are just longer lug nuts. The tacoma requires lug nuts that have a thread that extend inside of the wheel because of how little thread engagement there is.
2024 Tacoma Loading... 1734443338195-rz
Something similar to this. Where the thread extends past the conical seat. Otherwise you only get a few turns of thread engagement on the lug nut.
JED
Southern Tier NY
From initial thread engagement the subject lug nuts provide 11 full rotations of thread contact before seating in the wheel. The profile is the same as your example.
SpartanCaptain
PA
2024 TRD Sport
The et ones I posted will double the thread engagement. The factory ones are also et like the ones I posted. You may never have an issue with what you got, but it is just recommended to use the long ones.
JED
Southern Tier NY
I’m seeing ET referenced all over the subject lug nuts provide packaging:
2024 Tacoma Loading... IMG_7201
SpartanCaptain
PA
2024 TRD Sport
I see it says ET, but google searching that part number shows a lug that is not the normal extended thread.
Slappy
tacoma , highlander
718's here & same lug nuts from Method the wheels have swapped twice now replaced the stock tires with bigger
  • Like
Reactions: JED
