Lug nut size and type?
Tsturbo
Terry
WA State
‘24 Tacoma Limited
Finding conflicting information on the internet. For the 2024 Tacoma I am seeing BOTH 12m x 1.5 and 14m x 1.5, which is the correct size? And what is the correct type? (Acorn, splined, etc? Will be getting a LIMITED iForceMAX that has the chrome clad wheels which I am replacing with the 2024 OEM TRD 18” black wheels and I want to order black lug nuts also. It appears that OEM black lug nuts in 14m x 1.5 for the 2024 Tacoma are not available? Are OEM or aftermarket lugs better? Like Gorilla or ? Thanks in Advance!
Sner
M14 on the ‘24 M12 was on the ’23 - flat seat.
Powhunter
Alberta
I can confirm that the lugs for the 4th gen are M14x1.5 and the nuts are extended thread flat seat. If you are going with OEM wheels I would wait to order OEM lug nuts.
Tsturbo
Tsturbo
Terry
WA State
‘24 Tacoma Limited
Thank you!
Anyone know the OEM part number for the black lugs?
I just called a parts department directly and had them look up the lug that gets paired to the TRD Pro rim. Official part number for the 2024 TRD Black Lug M14x1.5 flat mag seat is 90942-A1008. Only sold in singles.
(Courtesy of Fred Anderson Toyota in Raleigh, NC)
trailhunger
US
2024 TH
Can anyone confirm if Trailhunter has this spec lug nut? I presume Bronze? Shopping for a set of gorilla wheel locks….
SpartanCaptain
PA
2024 TRD Sport
Did you ever find what the trailhunter uses? I just ordered those wheels and I want the matching lug nuts.
All 2024 Tacomas have identical lug specs...
It's just the color/finish that varies by wheel set
For the bronze, the easiest way is for someone with a Trailhunter VIN to call a parts shop and ask them to look it up. It's massively easier for them when they can quickly filter to a vin that has the part your hunting. Otherwise they have to read through all options and hope corporate spelled it out enough (I had to go through this with the upper bumper, where three of the six options don't clearly convey their uniqueness).
carlb4u
carl
marin California
2024 trd off-road hybrid
I did same thing!! yes to 14mm X1.5
OEM are avalible in black ,but they are around $18 apiece which come out to around $450
not willing to pay that much for lug nuts
got these on amazon :
MIKKUPPA 24pcs M14X1.5 Lug Nuts - 7/8" (22mm) Hex Mag Seat, Replacement for Replacement for 2022-2024 Toyota Sequoia Tundra 6 Lug Stock Rim Black
$36
Pappy
Jon
Intermountain West
Absolutely they are available. I just bought one for my spare tire mount.
