Red footwell lights?
Subwire
Subwire
Justin
Chico
2024 Tacoma Offroad
I have all my meso lights set to red for hunting season. Will change them back to white after season ends. I also installed the extra set of the door courtesy lights in the footwells so everything would match
That’s perfect. I have all the mesos too. I didn’t know I could use the extra courtesy lights.
Just to confirm...
Did you order an extra set? Or did they come with an extra set?
comes with 2 sets of lights.
Yotota
SW WA
24 TRD
When you purchase the courtesy lights they send you 4 so if you use the two in the doors just stick the other 2 in the footwells
Gotcha, thanks. I assume that our Tacos don't have lights in the rear doors, but other Toyota models do? (I don't have my truck nearby to check)
Subwire
Subwire
Justin
Chico
2024 Tacoma Offroad
Gotcha, thanks. I assume that our Tacos don't have lights in the rear doors, but other models do? (I don't have my truck nearby to check)
Ya the limited and above as well as 4 runners I believe.
Yotota
SW WA
24 TRD
Ah ha, thanks. So my TRD Off-road 4dr Taco with premium package would only have two door lights, freeing up the other two for footwell lights.
I'm digging this idea.
Subwire
Subwire
Justin
Chico
2024 Tacoma Offroad
yes, sir, that’s exactly what I have
Andrace
2024 TRD Off-Road 6MT
Using the extra lights in the footwell is a great idea, thanks for sharing that.
Subwire
Subwire
Justin
Chico
2024 Tacoma Offroad
Agreed, brilliant and so creative. This idea is gonna catch on like wildfire lol. I may do this but hang the lights with Velcro if I can so I can avoid cutting. But will cut if I need to.
I may try Velcro too. Have you done it yet?
Vidman
Rick
Mass
You’re going to have to be careful if using Velcro because the back of the lights are open with all the electronics exposed. That’s why I decided to do the cut instead.
2024 Tacoma Red footwell lights? IMG_1478
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
I took off the panel yesterday and I unclipped the OEM light then attached a Meso light. The wire is not long enough for me to Velcro it anywhere that will point the light to illuminate the space to my liking, so I will cut. First I need to get replacement lights from Meso since the mounts are broken even though the LED works. The mounts are broken over the exterior housing but the little piece inside that holds the circuit board to the housing.
(Edited because Siri screwed up the prose)
2024 Tacoma Red footwell lights? IMG_7994
lauren01
Lauren
Ventura, CA USA
Agree, I see what you mean after looking at it yesterday. I have a bunch of insulation on my panel so I will cut enough of that out of the way.
lauren01
Lauren
Ventura, CA USA
Quick update: Meso responded to my email within 3 days and sent a prepaid return shipping label. I’ll get that printed tomorrow and sent back to them. They will send replacements.
Airborne
Upstate,NewYork
So im thinking of getting the 4 set of MESO lights, is it simple install,? Pop the existing OEM lihgt out, install the new MESO light?, just plug in where the stock lights were, im a Jackass when it comes to wires, lol…if its that simple unplug old and plug newone in then thats my speed……..seems like popular upgrade a lot are doing im just not sure if its simple like the web site on meso says ???……any input would help, ill order them
thank you guys
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
It’s that simple. Pop out, unplug. Plug in, pop in.
Airborne
Upstate,NewYork
Thank you ,i appreciate response…im ordering them now lol
thank you again
lauren01
Lauren
Ventura, CA USA
thank you guys
Well, you do need to cut a hole like the guidance above indicates.
I got my replacement lights after three weeks from Meso. They sent a box of three. lol.
