Replacement larger fuel tank for gen4?
greenno
San Diego Cal.
2026 Tacoma Offroad
Does anyone make a replacement fuel tank for the gen 4 Tacoma?
With just 18g and only getting about 18mpg I have almost ran out of gas 2x.
My previous truck (F350) had a 48g tank underneath. I cried when I filled it up but had considerable range to not be filling up every week.
I know they probably make the in bed tank version and the smaller travel cans that you see bolted on everybody bed rack but I would rather replace the original underneath tank with one of larger capacity.
Pappy
Jon
Intermountain West
This subject has been beat to death. Nothing yet. Two companies are working on it. Go to Long Range America and get on the "wait list." Show some interest and maybe they will crap, get off the pot, and make us a tank. My preference is an auxiliary tank, instead of a replacement tank. But, I will take what ever I can get.
To make it easy for you, here is the link to the wait list:
https://longrangeamerica.com/waitlist/1741898750869x885361069156728800
greenno
San Diego Cal.
2026 Tacoma Offroad
F that noise. I’m not a patient man.
I looked at the Rough Country Molle panels to mount inside the rear bed and fasten up a 3g plastic can to that for like 3 bills or more.
AND they are not sized for the “longbed ” version only the 5’ bed. I’m sure it would work but, being inpatient, I will just make my own version.
I think Industrial Metal Supply by my house has flat stock for me to fab something up. Will probably figure out which design can best fits to base my design on.
I would like to mount it drivers side all the way forward flat along the side rail and not protrude out farther than the wheel well.
That way if I need it it’s right by my fill cap. I can just use my 6’ self priming siphon hose to fill and won’t even have to remove the tank to fill. Plus refilling the bedmount tank will be easy
Pappy
Jon
Intermountain West
Two options I use.
5 gallon NATO can on the rear bumper.
2024 Tacoma Replacement larger fuel tank for gen4? gas can-sm
3 gallon Rotopax on the roof rack.
2024 Tacoma Replacement larger fuel tank for gen4? rotopax
greenno
San Diego Cal.
2026 Tacoma Offroad
Got a bike rack on the rear so that won’t work for me.
I will figure something out this week and post up.
TFOUTS
Timothy
Northwest Florida
2024 Tacoma Trailhunter, 2003 Tacoma TRD OR, 2003 Toyota Sequoia
I think I read a while back that long range America has an auxiliary tank for the new land cruisers by removing the underneath, spare tire and mounting the tank. Hopefully they will do the same thing at least for my trailhunter. In the meantime, two 4 gallon Rotopax does the job.
FossilHunter
Toyota sells OEM Molle panels that fit the longbed for cheaper than most 3rd party
https://autoparts.toyota.com/products/product/inner-bed-molle-panels-side-pt76735800
greenno
San Diego Cal.
2026 Tacoma Offroad
I picked up a front bed section of Molly panel complete with hardware for less than $100 off e Bay.
Also found a 30L fuel cell and lockable mounting brackets for I think it was $130 again off e bay.
Going to horizontally mount he tank against the front wall having the fill cap right next to where my fuel fill door is.
I will just use my auto syphon hose, which is about 6' in length to transfer fuel into my main tank.
So gaining a little over 40% more fuel capacity for a little over $200 Im stoked.
parts should be here sometime this week. I will post up a pic after getting it mounted up.
Cheap and easy solution for me anyways.
Pappy
Jon
Intermountain West
That sounds promising. I don't like the 24 gallon size. I would prefer something in the 15 gallon range to keep the weight down on the rear end. At least it doesn't look like it hangs down as much as I would expect for a tank that large.
Pappy
Jon
Intermountain West
Up to the top we go. I just contacted a company that makes aux tanks for other Toyotas. I asked them about a tank for our trucks. Their response ... "We will be announcing the 4th gen Taco tank within a week and it will be 18 gallons."
Comparable tank for the LX, LC and 4R is $2300.
Company is https://helivuedesign.com/
