don’t really want to trim brand new fenders. Maybe I’ll go 34’s.no effort really to fit. Slight trim on the rear of the fenders. Remove crash plate. That’s it.
do you have a lift?
yes. Full suspension. Kings. Total Chaos Upper control arms.don’t really want to trim brand new fenders. Maybe I’ll go 34’s.
do you have a lift?
Well,excuse me. Cool kid over here.yes. Full suspension. Kings. Total Chaos Upper control arms.
planning on a solid axle swap and 42s. Until then. I’m sticking to this setup.
I just wanna keep up with the guys on the rubicon.Well,excuse me. Cool kid over here.
Can’t blame you.I just wanna keep up with the guys on the rubicon.![]()
Hey dude. What trails do you have nearby?I think 37s are more than plenty / with 40+” tires the gear strain will be pretty severe unless you regear / also will be lots of strain on various components
The golden mall crawl rubicon trailHey dude. What trails do you have nearby?
	I don't have mine yet but it's going to be almost exactly this (see pic at bottom). I found these pics on autotrader, hilariously exactly identical to what I have on order, same truck configuration, color, lift, wheels, wheel finish, and tires.
Wheels are Method 703 35mm offset, Tires are 285/75R17 Toyo AT3 in load range C.
Tires will weigh 59lb per, which is a substantial increase over the stock 36lb per tire. That said, Toyota uses cheap disposable tires as OEM, the real version of the OEM tire with full tread weighs 6lb more (42lb per tire) according to Tire Rack.
I can't offer any data on how it drives....I don't have mine yet. It's in transit and even when it gets here the wheels/tires don't arrive til late September.
My understanding is this will fit with the factory lift, without removing the crash bars.
This video from ReadyLift shows what fits on their 1.5" lift: The OEM lift is 3" front + 2" rear, so I assume everything that fits on that will fit fine on the factory lift. It seems like 35mm is the most offset I want to go for 285/75R17 (34s)...but maybe 25mm is possible too.
Also recommend watching this video where they also did 285/75R17:
The other thing I've read is that sticking with load range C is very important.
	I’d go with 34s minimum and stick with the 17” rim - 285/75/17. I wouldn’t go any smaller imo with the factory lift. Here’s what mine looks like. My Method rims are +25 offset to give them just enough poke. I get about 18mpg city and 20.5mpg hwy. I think 35s would be perfect but I want to save some mpgs. I went with C-rated Toyo Open Country A/T III.
This is perfect to me. Got a picture from the front?I’d go with 34s minimum and stick with the 17” rim - 285/75/17. I wouldn’t go any smaller imo with the factory lift. Here’s what mine looks like. My Method rims are +25 offset to give them just enough poke. I get about 18mpg city and 20.5mpg hwy. I think 35s would be perfect but I want to save some mpgs. I went with C-rated Toyo Open Country A/T III.
