Spring lift or collar lift?
Jeff11
Pittsburgh
2025 TRD OR
Hi everyone! Looking to lift my TRD OR between 1 and 2". The two options in considering are a preload collar lift like Peak Suspension has (just the collar, not top spacer), or the All Dogs Off-road spring lift kit. All Dogs would probably give a slightly higher lift, but that's okay. My question is, what are some opinions on one vs another, pros, cons, etc? Thanks! (Also would be either installing the rear spacer if I go with peak, or the rear springs with All Dogs, as I plan to keep the rake).
Wife bought my 24 TRD
Anthony
Aberdeen Wa
Check out the video Running 4 tacos. Put out on the All Dogs Springs. Personally, I wouldn't go with a spacer lift because it limits your travel. I just got done. Putting a full king suspension Lift on my taco and absolutely love it. I picked it up from running for tacos, and they are very helpful.
2024 Tacoma Spring lift or collar lift? 20250409_171926
Jeff11
Pittsburgh
2025 TRD OR
Thanks! I Don't want a spacer lift in terms of the top hat space. If I don't go spring lift, it would be a preload collar lift.
tkrum015
Ted
Olympia
Love the truck looks like the beach in WA. Where do we find the video?
mikeymtbs
Atlanta, GA
24 TRD Offroad Premium
Coller or spacer, neither are as desirable as a proper spring lift.
tkrum015
Ted
Olympia
Thought you were near there. I am from Olympia.
tkrum015
Ted
Olympia
You have a very nice work truck.
Mini2nut
2026 Tacoma Trailhunter
Spring if you can afford it, collar if you can’t.
mattski2112
Georgetown, TX
Pretty sure the ADO spring lift is actually a bit less work than the preload collars as there’s nothing to disassemble on the shock shaft beyond the top hat nut.
Anthony
Aberdeen Wa
Thanks, but fortunately ☺ I am early retired at 55. My taco, aka (The Widow) She is my mid life crisis paid for by my wife.
I'm building this for overlanding
Sanhema roof tent ( this week )
Bunkers 270 awning ( already have)
Waiting on canopy.?
Full graphic wrap
Still have front aluminum bumper winch rear winch bumper and swing out Planning on camping all over the state with the wife and I hopefully, we'll hook up with groups
2024 Tacoma Spring lift or collar lift? 20250409_172044
Powhunter
Alberta
ā€˜24 TRD OR 6MT DCSB Underground
Functionally, a preload spacer and a longer spring are going to do the exact same thing. Unless you want a different spring rate due to a lot of extra weight, I can’t see any reason to buy new springs over a preload spacer. Both options will reduce your shock travel though, however, the TRD off road model has extra travel for the sway bar disconnect option due to the remote reservoirs.
With the integral bump stops on the new generation shocks, the downside to a top hat spacer is now gone too. You also won’t lose any shock travel with a top hat spacer. Provided your stock ball joint angles aren’t too out of whack.
