Strange Annoying Rattling above 30mph!
25ORP
Vancouver BC
2025 Tacoma ORP
I was on tacomaworld and tried this 2 days ago. Not my issue but I have that same ticking rattle from door area on driver side. Its sound like all videos on here. I saw one post from @Tony with tape and foam all over his truck. I felt like I was alone with the struggle but maybe not
hagglethorn
Russellville, AR
2019 4Runner, 2004 Yamaha FZ1, 2022 Kawasaki Versys SE LT+
I was having a very annoying rattle above about 30 mph coming from the front and at times both sides, sometimes alternating sides! It started about 2-3 months ago at about 15,000 miles. I tore through damn near the entire front end trying to find it! Ended up being the engine splash guards in the wheel wells! I tapped them with my finger and they made the annoying rattle. I’m assuming the wind above 30 mph must have been causing them to start flopping and making the noise? The fix was simple, just remove them and put 2 layers of electrical tape over the holes that they attach to, then cut an X in the hole so the push pins can slip in to make a snug fit. There are 2 on each side, wasn’t certain which ones were the problem so I completely removed them and taped every hole.
There’s 2 of these in each wheel well for my Taco. There’s a smaller one forward of the one pictured. All 4 were floppy as hell. And one fastener wasn't even pushed in on the left front! Huge thanks for finding and posting this!
Yeah, all 4 got the electrical tape treatment 👍
Stringburner
West Virginia
2025 Toyota Tacoma TRD Off Road 6MT
Mine has it, too. I've been meaning to fix it, but always forget. I mostly ride with the windows cracked or down, and with the wind noise you don't hear it at all. If you have the windows up and the music isn't playing, it's extremely annoying. I can't believe it got past initial testing before the truck was released.
tacomasport1121
Robert
2024 Tacoma Sport
Thank you so much!!!!! I kept hearing this rattling I swore was in the driver side door or A pillar. Only above 15 mph. I tapped my driver side splash guard tonight, and sure enough, super loose. Checked passenger side and didn’t make a noise, right and secured.
Wondering, what trim do you have with 2 per wheel well? I have a TRD Sport and only see one in each wheel well.
Off Road, yeah, I had my a pillars apart, kick panels, hood and engine bay trim, and front bumper cover apart looking! I was happy and pissed when I found what it was 😡😂
tacomasport1121
Robert
2024 Tacoma Sport
Hahahaha. I appreciate your hard work! 🤣 I’m going to tackle the rattling this weekend and will report back with what I find. 👍
hagglethorn
Russellville, AR
Mine is the TRD Off Road as well. Did I see somewhere that the TRD Pro has these big (maybe) single piece wheel well liners? Wonder if that would be a good solution… certainly much more $$$$.
hagglethorn
Russellville, AR
I don’t have time to find the correct size for a while, I don’t think 7mm inner diameter will be the right size, but the idea is there
I measured. 8 mm would be the right size for the hole. The head of those plastic fasteners is 17 mm.
SnowmanJPS
Halifax, NS
2025 TRD Pro
I guess foam 7mm could stretch 1mm or I could find 8mm washers some time, thank you for your work
