I've seen various threads discussing retrofitting the OEM Trailhunter air compressor to other Taco trim packages but nothing conclusive. I just wanted to give a quick post to verify firsthand that it is in fact possible and to give a quick DIY, even though installation is pretty easy.
Ordered the part from Elmhurst Toyota, in IL part number is Toyota (PT949-35240). They had the cheapest price I found on the internet which was $988.75 + $70 shipping. Shipping took about a week and inside the shipping box came 1) the control box, which replaces the factory cubby with usb outlets 2) the compressor 3) a nice red inflator tube in a toyota branded pounch. It also comes with at least 10 T27 bolts. I was stoked about this because I didn't think it would come with 3) based on what I had read.
1, 2, and 3 from left to right.
First thing I did was remove the existing cubby. This is trivial, just 4 torx bolts (T-27 i believe) and unplug the gray connector. Be careful it's brittle! Installation of the new control box is just the opposite of removal.
After it was installed, I verified the unit was getting power and to my relief:
Before I went to install the compressor, I decided to make a gasket for it using 1/8" rubber since the control unit had one and the compressor did not.
Now the only real hard part of the installation, cutting the bed and fitting the compressor unit. I decided to cut out the compressor unit using a cordless router. I wore a mask since the fiberglass really gets thrown around the air. To do this you'll need to measure where the bolts will go using the unit as a plan. Be careful, the middle bolts are not symmetrical (ask me how i know!)!
There are 8 total holes that need to be cut (6 bolts + 2 stabilizers that come off of the compressor housing) AND the big center hole for the compressor itself to fit through. Unfortunately I didn't get any pictures of this because it started raining harder right after i took this pic. That being said just take your time with it, it's definitely stressful to cut into a brand new vehicle, just make sure you're not cutting anything behind the bed that you shouldn't be and go slow. Also obviously, I removed the control box while installing the compressor.
To secure the compressor unit, I opted to install rivet nuts into the bed, similarly to how Toyota OEM did it for the control box above. I used this rivet nut tool from amazon. You can also just use regular nuts if you want. The bolts are M6 and come with the compressor as i mentioned above. You can easily access the back of them either from under the truck or by taking out the control unit.
Once the compressor is securely installed, it's just a matter of connecting that to the control unit and reinstalling the control unit. There are 4 connections you need to make before buttoning things up: 1) silver supply air connector from compressor to control unit 2) blue sharkbite-style hose from compressor to control unit for airing down 3) gray power connector going from truck to control unit 4) black power/sensing connector going from control unit to compressor.
Congrats! You now have a compressor you don't have to open your hood for and lug around. I especially like that you can set a target PSI to air down to and the unit will do that automatically. I've tested airing up and down with a Morrflate 4-wheel hose setup and it works great! One thing I noticed is that the PSI measurement isn't always perfect so I would use a secondary tire pressure tool in the loop just to be sure.
Overall a very easy if sometimes stressful (bc of cutting) install. Excited to put more miles on this setup this summer!
