Transmission temp while climbing in 4H
Muckle
Washington
I finally got to stretch the legs of the Tacoma a bit. Took it up Hart’s Pass in the northern Cascades all the way to the Slate Peak Lookout. Absolutely beautiful climb and highly recommend it.
It was a sustained climb lasting about 1.5 hours with a few brief stops, gaining almost 5,000ft. The majority of it was in 4H.
I did notice the transmission temp increased a bit during the climb. Where it normally sits at about 50% of the gauge meter, it climbed up to 75% before I took a brief break and it cooled down. I tried bumping it down to 2WD but that didn’t seem to impact the rising temps much.
Is this to be expected when you’re in a sustained climb without relief? I can’t imagine pushing it much further than this without more breaks - I was in a time crunch so was pushing for the summit.
2024 Tacoma Transmission temp while climbing in 4H IMG_1079
2024 Tacoma Transmission temp while climbing in 4H IMG_1077
2024 Tacoma Transmission temp while climbing in 4H IMG_1049
tacoboutit
2024 toyota tacoma trailhunter
TFL Truck guys noticed that too while towing at elevation. Their conensus was the truck handled it well, as there were no symptoms of stress for lack of a better word. They concluded that maybe newer trucks are just built to sustain higher temps now? They did mention several other trucks had failed where the taco succeeded. I'll post a link to the vid here:
Gfenza89
Gary
2022 tacoma sr5
I think be because the new tacoma has an oil and trans temp gauge people are able to actually see the temps and it’s alarming but completely normal. Prior tacos had no such gauge therefore without a warning light on it was no concern. Just my 2cents
32spoke
Jason
Petaluma,CA
You are not alone in this observation.
I will be installing a transmission oil cooler with a fan attached to it, on the return side of the OE trans heat sink…Plenty of room to mount this underneath the truck. Fan can be switch actuated from the dash, or by a fan temp switch.
great photos and thank you for sharing your concerns and “content “
batman900
Oklahoma
24 Tacoma OR
I'm not educated enough on the 2024 taco but I know with the previous gen Tundra, once they removed the proper cooler in 2019. Manually selecting a lower gear for higher rpms helped with the trans cooling. I also don't know under what situations the torque converter will lock but keeping it locked should help. I ultimately ended up adding a cooler to my 21 Tundra and stopped thinking about it.
Oh, and despite the higher temps and everyone worrying about them with the 19-21, we never had failures because of it.
wutheck
Jeremy
Sparks Nevada
2024 Toyota Tacoma TRD Sport
Same for me in 4 Hi. If I run it around in 4 Lo it stays cool.
bking
Bernie
2024 Tacoma TRD Offroad
There was a video a while ago from Jace Robinette where he was having issues with transmission heat offroading in 4HI. It never did get dangerously hot.
Later he posted that when he switched to 4LO it didn't have a problem. I do agree that much of this has to do with having a gauge now where before it didn't exist.
Duck Amuck
Alberta, Canada
24 Tacoma TRD Off-Road/17 MINI Cooper Clubman S
There was a YouTube video a while back of someone putting 35"s on their fourth-gen, they said it did cause transmission temps to increase but that putting it in tow/haul mode helped bring them back down. Might be worth a try.
Sandeep1994
Taco4gt
I have off road manual
. Funny thing is when i bought this truck i didnt knew that there is no transmission cooler for manual transmission . So looking at gauge i found it odd that why my truck has no transmission temp gauge . Every other truck i saw in youtube had trans gauge . But then figured out that all those trucks were automatic
24blancotaco
Kobe
2024 Toyota Tacoma
First hand experience with this. Except while climbing in 4hi the temperature got to hot and my engine lost power. Then I got a notification on my dash to put it in park and allow the transmission to cool. Was fine after but yeah definitely heats up quick in 4hi on steeper climbs. Side note my truck is in the shop now due to a weird chirp coming from the engine bay that seems to only get worse the longer you drive it. Not sure if the transmission getting too hot might have cause this but the Toyota techs can’t figure out the issue.
Long story short, 4lo and slow
Super_Trouper
Georgia
'24 TRD OR
What gear were you in for your 4 Hi climb? if you were just in drive, go into manual mode and lock it out into a lower gear so you're turning more RPMS and thus cycling the trans fluid more. I'd bet that's why 4 Lo doesn't exhibit the problem.
CrispyTacoLover
You wouldn’t think 4hi would be in too high of a gear when elevation climbing.
Yotota
SW WA
24 TRD
I had this exact thought the other day while driving.
Either use manual shift mode to keep the revs up, or put the truck in Sport Mode or maybe Tow/Haul Mode (especially if the truck is heavily loaded). Then the trans won't slip as much and temps will stay lower.
Super_Trouper
Georgia
'24 TRD OR
4 Hi will function just like 2wd as far as trans goes, so it's going to shift into the highest gear possible to keep RPMs low. Throw that sucker down a gear or two in manual mode to tach closer to 3-4k and you'll probably see the issue resolve itself because the fluid is being pumped faster through the trans cooler.
