Westcott Lift Kit Installed on 2024 Tacoma OR Long Bed
JED
JED
Southern Tier NY
2015 Tacoma TRD Sport
I’m underground OR 6’ bed
QUOTE="Drakka01, post: 56866, member: 4098"]
Very nice. Not doing a lift but I am waiting on my Westcott roof rack. Hoping they get it out the door soon so I can post some pics of it here.
[/QUOTE]
[/QUOTE]
a combination yet to be seen I believe!
av8r
Southern Tier NY
too many
@JED where in the southern tier are you? I'm also in that area and waiting on a TRD Pro. Just drove a couple TRD Sport at Williams in Bing.
Wukong
IN
TRD ORP
@JED did you get your truck and Westcott lift installed yet?
Wukong
IN
TRD ORP
Yep. Couldn’t be happier.
Congrats! Looks awesome. How's the ride quality on the Westcott lift kit?
Can you share your tires & wheels specs?
JED
JED
Southern Tier NY
RollingThunder
Oliver
@JED is it me or doesn't it look like after the westcott lift you still have a rake in the rear? Did you level it or just do a lift kit?
JED
JED
Southern Tier NY
When first installed there was 1/2” difference front to back. I do see a little rake but nothing like stock. The kit installed was 2 1/2” front 3/4” back.
JED
JED
Southern Tier NY
You had me wondering so I went out this morning and measured again with the lift installed almost 2 months. Now measured 23 1/2” front (center of wheel to underside of fender) and 24 1/2” in the rear. Coils “settled in “ I guess.
RollingThunder
Oliver
Thanks for checking. So it sounds like after it "settled" it isn't too far off from factory rake which I think is 1.5" per this Westcott video:
After installing the westcott preload collar kit (2.5" & .75"), if the factory rake is 21.5" in front and 23" in rear, after the lift there should be a reverse rake of 24" in front and 23.75" in rear. But that doesn't seem to be the case with your truck?
The peak suspension (2.25" & 1") would still leave you with a slight rake of .75" (23.75" in front and 24" in rear)
Trying to decide which kit I want to go with but if the Westcott one is still leaving a 1" rake, I'm wondering if the peak suspension is the one to go
gofastdan
After installing the Wescott kit on my OR LB I was almost 1.5 inches of rake still from front to rear and that's three weeks and 1,000 miles after the install so everything should be fully settled. I got my wedge camper and batwing awning, which together add ~450lbs, installed last Friday and now it's almost perfectly level.
I've wondered if the alignment has anything to do with the continued rake after install but the shop I had do the alignment is fairly reputable and has done alignments on other vehicles for me in the past with no complaints. I'm not prepared to spend more money just to have another shop verify the alignment so for now I'll just shrug at the mystery of it all.
