Will it fit without rubbing and modification
SilverSurfer
Tacoma TRD OR Premium Plus
I went to America’s tire because I wanted to see the Nitto Terra Grabber G3 and Toyo OC AT3 EV tires in person. I talked with them about the tire’s fitment on the Methods I recently bought.
Wheels: Methods 316 18 x9 6x139.7 + 18.
Tires: 275 70R 18.
Basically, they said that tire size is in their red zone for potential rubbing and they recommend 275 65 R18.
Does anyone know for sure? Is there a site I can put in these specs and get a go/no go Before wasting money having them install tires that won’t fit without rubbing or modifications?
Here’s a shot of KO3’s in that same size in my wheel Well
2024 Tacoma Will it fit without rubbing and modification IMG_4671
SilverSurfer
SilverSurfer
I found this, but I would think someone here has experience with the size I’m looking at.
2024 Tacoma Will it fit without rubbing and modification IMG_0104
2024 Tacoma Will it fit without rubbing and modification IMG_0105
SilverSurfer
SilverSurfer
Thanks for putting this in the right spot, admins. I’ll be sure to do that the next time. :)
24TacomaGirl
Robyn
Arizona
I have Michelin LTXs 275/70/18s (On stock TRD Sport wheels — with the 55 offset) and it is NOWHERE near rubbing anywhere on the front on stock suspension. Not sure how true the ones you are to size but mine are 33.2” and it fits GREAT.
SilverSurfer
SilverSurfer
Thanks, that’s good the hear. It sounds like only my offset +18 is different from your setup. I’m going to a Indy shop this morning and the owner wanted to manually measure clearances and will then advise on what he thinks will fit. I’m hoping I can truly fit the 275 as it’s the height and size that I think looks best.
MNTBKR
Luis
Central, FL
This video goes over different size options, I'm not sure if your particular set up is covered but it should be helpful.
SilverSurfer
SilverSurfer
Thanks, I had a local tire shop test fit a 275/70/18 with a tire they have on hand and it’s just barely squeezes in. The tire i want is .15 wider than the tire they measured with. Probably will work. we’ll know when the tires arrive. I ordered Method’s lugs yesterday.
2024 Tacoma Will it fit without rubbing and modification IMG_4682
2024 Tacoma Will it fit without rubbing and modification IMG_4685
2024 Tacoma Will it fit without rubbing and modification IMG_4688
W13NY
Will
NYC
2025 Toyota Tacoma
So the 275/70/R18 fit on the stock suspension with no rubbing even at full lock?
Im on the fence on what to get I was leaning towards 275/65/R18 with the factory wheel of +55mm offset because thats what I keep seeing as the largest tire that fits without rubbing on a stock suspension.
Any insight you can provide is appreciated.
