Hydrophobic air filter cover for Trailhunter?
tnjwinters
Tim
2017 Tacoma TRD Pro, 2024 Trailhunter 6’
Has anyone come up with a hydrophobic air filter cover for their Trailhunter?
Interesting question. I heard it has drain holes to let water out that gets in from the top - is your intention to seal that up and then add a waterproof filter?
tnjwinters
tnjwinters
Tim
Just wanted to add the water resistant cover for extra protection.
trailhunger
2024 TH
Maybe something like
Yea if there’s an imminent storm on the way - rain sleet or snow - having a waterproof sock over the intake isn’t a bad idea until you forget about it one day and remote start.
tnjwinters
tnjwinters
Tim
No, not over the intake/snorkel it’s self but over the cone air filter as a pre filter that always stays on.
tnjwinters
tnjwinters
Tim
Like this
2024 Tacoma Hydrophobic air filter cover for Trailhunter? IMG_0126
jss1
Kentucky
Have you installed a pre-filter? If so, which one and how has it been going? Thank you.
tnjwinters
tnjwinters
Tim
I have not. I was hoping for some recommendations. I might look at it more this next weekend.
tnjwinters
tnjwinters
Tim
So I purchased and installed today a “Filterwears” K338 pre-filter. Used a 6” clamp to secure and went for a drive. No issues so far. Will check in a week or two to make sure it stays in place. I hope that if water does get into the intake this winter that this stops any water entry into the engine. I did verify there are two small drain holes in the filter box. Bonus is that as this truck has a washable air filter and now a pre-filter, this should help to keep it clean as well.
2024 Tacoma Hydrophobic air filter cover for Trailhunter? IMG_5058_Original
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
Appreciate the link to this post and tip to strap on a clamp. The Filterwears part number I have is different-hope it is because it is updated for 4G. I got this in April ‘26. Will wash filter and give this a try.
Ordered yellow to help me see the red oil when inspecting.
2024 Tacoma Hydrophobic air filter cover for Trailhunter? IMG_5816
tnjwinters
tnjwinters
Tim
Let me know how it fits and what you think. I bought two so that I can swap out a clean one when I check the filter without having to wait to wash and dry.
Kodachrome
2005 Tacoma TRD Offroad, 2026 Tacoma Trailhunter
So to be clear, these are K&N oil type filters? If so, I am not a fan of those in general because it is easy to under or over oil them. On my 2005 I run a set of AFE dryfit filters that I rotate out every oil change, rinse and then dry, no oil.
I am wondering if you use this hydrophobic filter on the K&N but do not oil it if that can help take the place of the oil in terms of catching debris? Of course there is the standing issue of water coming into the snorkel while in boost in heavy precipitation that might sway that equation back towards the oil.
Either way and right out of the gate, I want to get a second or even a third filter to have ready to go on oil changes, I am strict about this to maximize airflow into the fuel mixture.
Rising Sun
North Georgia USA
2025 Toyota Tacoma Trailhunter
Yes the Trailhunter and TRD Pro come with an oil on gauze (K&N style) filter from the factory.
Kodachrome
I just confirmed that and ordered a spare filter, pricey sucker. Back to oiling, ugh...
