Westscott pre collar lift install shop in Socal?
jorge98thhh
Los Angeles
Toyota Tacoma SR5
Any recommendations of any shops in SoCal that are familiar with Wescott designs pre collar lift? Looking to install, will be supplying parts. Got quoted $800, does that sound right for the price?
RicosTaco
You can use your ZIP code on the Wescott Designs website to find distributors that not only sell their products but also offer installation services. If your budget allows, opting for professional installation ensures the job is done by experienced technicians. From my experience, installing a Wescott preload collar lift and wheels took only a few hours, with the longest part being the wheel alignment process. Also, Wescott designs customer service is outstanding, I'm sure they'd be more than willing to help as well.
Now go get that lift installed and enjoy your awesome truck???
jorge98thhh
Los Angeles
Toyota Tacoma SR5
thank you so much, this definitely helps a lot! question what are you running for tires & wheels
jorge98thhh
Los Angeles
Toyota Tacoma SR5
I'm running Method 703’s with a +35mm offset on Bf Goodrich’s Ko3s at 285/70R17 The poke out is just right for me.
That thing is looking spiffy clean!! I’m shooting for something like that with a topper
RicosTaco
You've to post your truck once you finished installing all your gear! Can't wait to see it!?? I know it's going to be sick!
RicosTaco
@dvrgz, I've Wescott Designs preload collar lift kit. 2.50” on the front .75” on the rear. Hope this helps?? it was a fun install.
BearTacos
West
Central Indiana
For the guys running the collar system, have you put any weight in the bed? I'm curious if the truck would have a bad reverse rake to it. My bed is normally empty but will put 700 lbs in it for hunting trips.
JED
Southern Tier NY
2015 Tacoma TRD Sport
In my case the coil springs settled out from 1/4” to a 1” rake after a few months. I’m OK with that.
jorge98thhh
Los Angeles
Toyota Tacoma SR5
Finally got it done!
Westscott design pre collar
Rrw 17 with nitto grappler 285/75/17
no rubbing but they did remove the guards and mud flaps
2024 Tacoma Westscott pre collar lift install shop in Socal? IMG_0335
slater
san diego
2024 tacoma sr5/2wd, white
Im running their collar on 275 75 17 Falkens, since November...
Didnt have to touch the crash plates....
RutsyBucket
Hunter
Carlsbad, CA
2025 Terra Off Road
Looks like my friends old place in Venice. Looks good, can't really tell because its so dark!
