Cali Raised LED
Jake
Fort Worth, Texas
4th Gen Tacoma
Welcome
Cali Raised LED
www.CaliRaisedled.com
Phone: 888-385-5036 l Email:
[email protected] l Instagram: @cali_raised_led
https://caliraisedled.com/products/dash-mount-for-2024-toyota-tacoma
If you're running comms, GPS, or a trail tablet in your 2024 Tacoma, a stable dash mount is a must. We designed this no-drill solution specifically for the 4th Gen dash layout to give you clean mounting points without blocking visibility or vents.
Whether you're overlanding or just need a hands-free phone setup, this system gives you a rock-solid base that won’t shake loose on washboard roads.
Key Features:
  • Vehicle-specific fit: Designed for the 2024+ Toyota Tacoma (4th Gen)
  • No drilling required: Installs using OEM fastener points
  • All-metal construction: Powder-coated steel for long-term durability
  • Modular layout: Mount devices using RAM balls, 67mm balls, or other compatible systems
  • Low-profile design: Clears factory screens, vents, and visibility zones
We engineered this to stay tight under trail abuse and daily use, using factory hardware locations to avoid hacking up your dash.
Install Notes:
Takes about 10 minutes with basic tools. All hardware included. Reuses factory fasteners under the center trim piece—just pop the top cover and go.
Will this fit the 2025 Tacoma?
Yes, Toyota carried over the same dash configuration into the 2025 models, so fitment is confirmed.
Can I run this with a tablet?
Absolutely. The flat mounting surface and universal hole pattern make it compatible with RAM and other systems. It’s built to support heavier devices without flexing.
Product Page:
You can check it out here: 2024 Tacoma Dash Mount – Cali Raised LED
Let me know if you’ve already installed one or have questions—we’re always down to help with setups.
Install Video
theKurt
Kurtis
Calgary, Canada
2024 Tacoma Sport+ 6M
Nice unit. Not cheap, but I guess it is a good sized chunk of milled aluminum. The T-slots are a nice feature. It looks like the 8" version has threaded holes as well. Is that correct? If so, are they of a particular standard bolt pattern?
jsuber
juke
Jls297#40601
UPDATE: I ordered one. It ships in a few weeks. Also ordered a pair of ball mounts and the phone mount. I like that I can mount my phone and my dash cam or GPS there. I use the GPS when off the beaten path because 5G might not be available. I also like that it’s aluminum And secured in place with four screws. Now I have to move my Amazon dash bucket to my RAV4. Hope it will work there.
I like it. But I think FHP would not be as thrilled if they saw it tricked out with a number of obstructions. So I have to get one.
theKurt
Kurtis
Calgary, Canada
Thanks for being the guinea pig for us! If you could report back once you get it installed, that would be appreciated. I'm interested to know if you find it to be a useful mounting point.
jsuber
juke
Jls297#40601
I will. It has already shipped and should be here Thursday. I have a phone mount and I am mounting the Garmin Overlander GPS as well.
jsuber
juke
Jls297#40601
I received it Thursday. All did not go as advertised but it looks great and very functional. Issues with the 6x40mm installation screws and they did not thread well and they did not match the color scheme. So I used some black 6x20mm approved by the Amazon Gods and they worked well. Also had to remove existing screws which were bevel threaded. But all in all it worked
2024 Tacoma Dash Mount for 2024 Tacoma – Secure, No-Drill Fit for Your Tech IMG_4243
2024 Tacoma Dash Mount for 2024 Tacoma – Secure, No-Drill Fit for Your Tech IMG_4242
2024 Tacoma Dash Mount for 2024 Tacoma – Secure, No-Drill Fit for Your Tech IMG_4244
2024 Tacoma Dash Mount for 2024 Tacoma – Secure, No-Drill Fit for Your Tech IMG_4250
2024 Tacoma Dash Mount for 2024 Tacoma – Secure, No-Drill Fit for Your Tech IMG_4251
2024 Tacoma Dash Mount for 2024 Tacoma – Secure, No-Drill Fit for Your Tech IMG_4249
MHG
Mark
Long Island
2025 TRD Offroad
Being that the 14” inch infotainment screen in the Toyota is just a giant extension of your phone with the addition of camera views, you can not add another giant screen. I do like the mount system . Great for an insta 360 mount.
jsuber
juke
Jls297#40601
Mine is smaller than the 14” in the premium Yotas and as someone that travels in the state and national forest you cannot depend on the cellular system so I have the Garmin Overlander. 75% of my county is state and national forest and our population is less than 40k and we are on the Gulf of America
theKurt
Kurtis
Calgary, Canada
Nice! Thanks for the review and writeup!
Cali Raised LED
Cali Raised LED
Jake
Fort Worth, Texas
4th Gen Tacoma
I like this, and wonder if anyone has installed this recently?
Yeah, actually—several folks have installed that recently and shared solid feedback. Super clean fit, especially with the newer revisions.
What rig are you thinking about putting it on? I can probably point you to a few recent installs or common tips (like clearance notes or wiring tweaks) depending on the model.
Cali Raised LED
Cali Raised LED
Jake
Fort Worth, Texas
4th Gen Tacoma
heads up, we’ve got the 2024 Toyota Tacoma dash mounts for phones, tablets, and GPS devices back in stock and ready to ship.
? They bolt cleanly onto the factory dash—no drilling needed.
? Secure hold for even the roughest trails—keeps your gear right where you need it.
? Made right here in the USA, powder-coated, built to last.
If anyone’s still tuning their rig and needs a solid mount for navigation or media, these are available and ready to go. Let me know if you want fitment tips or to check compatibility—happy to help.
2024 Tacoma Dash Mount for 2024 Tacoma – Secure, No-Drill Fit for Your Tech tacoma-4th-gen-tacoma-dash-mount-03
