goin2drt
KY
I've had my Taco since July 6th, and since that day I've had a list of links to future upgrades I knew I'd want. One of those links:
53101-AK070 - Grille Sub Assembly Rad - Toyota Parts Delivered
At the time the price was $273 for the heritage grill, but I see it has since come down to $268. These part numbers were not mysteries in early July, and these grilles have been fairly readily available at dealers across the country, all for much less than the price gougers at YotaGarage. You'll come out way ahead even having to buy a bracket/light separately than what Rave and Yota are offering.
ETA: I didn't realize that for $400, YotaGarage isn't even throwing in a camera bracket ?
Comparing apples to oranges. Even says in big bold letters, local pick up only. The cheapest shipping I have found is $120 from a dealer. My local dealer and plenty of other do not discount.
2024 Tacoma Heritage Grille -- OEM and Aftermarket Options Screenshot 2024-09-05 162729
that_frenchman
Alex
Austin, TX
Astewart23
Alex
I just purchased my Trailhunter Grille yesterday and it already shipped out, should be delivered on Thursday. Can't wait to put it on the truck. Thought i was gonna have to wait a while to get it, but shipped out next day.
taco4moro
Los Angeles
2024 Tacoma TRD ORP
where'd you order from and how much did it run you?
Astewart23
Alex
After taxes it was $428 thru The Yota Garage which is i know is expensive, but the fact it shipped out next day, I dont regret it. Everywhere else I was looking had EVA'S of weeks to months or more. I also picked up a Diode Dynamics 20 inch light bar thru Rave Off Road with there light bar mount made specifically for this grille.
dalucca2003
So I purchased my Trailhunter front grille from a Toyota dealer and can't wait to install it. I have a question in regards to a front camera install. My Sport package did not come with a front camera installed and was wondering if there is one available to purchase and also is my Sport pre-wired for one? If not, is there a way to plug the hole?
Darkhorse24
NC
It's a double edge sword in some cases.
I did the math of ordering each part individually (grill, light bar, wiring harness, camera bracket, dash button) and when I added in shipping charges and taxes, I was within a minimal $$ difference of just sourcing it all from them as one kit - and having the necessary mounting brackets for the light bar rather than having to fabricate the camera mount or the brackets myself (I don't have a 3d printer like Gurvy does). So the delta in total cost was small enough that the hassle of ordering as a bundle from a single place was the winner.
... that said... YotaGarage is nothing but a gouge house on their pricing. Everything is 2-3x what it should be and even way above Toyota SRP.
Since you’ve done the research, what light bar actually fits? 18” or 20”
diverjm
Jordan
CA BayArea
24’TRD OffRoad
Speaking for the OEM grille, It’s designed to be used with a 20” light bar. Heretic has a 20” bar that fits perfectly. Other options are a 20” by Baja Designs which needs some minor cutting done to the grille for fitment or an 18” by Diode Dynamics that will have space on both sides since it’s technically smaller. All options have brackets sold by Rave. I went the Heretic route and I couldn’t be happier.
Darkhorse24
NC
Thats what I’ve noticed too. I bought the BPFabrication bracket which doesn’t require any fabrication and will mount either lightbar (S8, Rigid SR-Pro, Diode Dynamics 18”, etc, since it’s a 18x1.6” lightbar cutout but I’ve been hesitant to buy an 18” since it will leave gaps versus a 20” which requires notching)… but the 18” light bars are hard to find except for 2-3 companies like Diode or mPower, but the 20” can get costly just for an extra 2”. I considered the Baja setup that has the S8 with dual S2 Pros but that’s a $1000 and they don’t sell the bracket alone. Anyways, whether it’s Rave (who shows you the options for 18-20” on YouTube) or Rigid, Diode or Heretic (usually all DIYers like @graytaco (really good video: ), but no one shows the video of what needs to be cut or how sturdy the mount will be after since it’s got quite a bit of plastic removed.
This is the one from BPFab that doesn’t require any modification and as long as it’s <20” will fit in the cutout. Not bad for $100
https://www.bpfabricating.com/colle...o-and-trail-hunter-univeral-light-bar-bracket
I went with Diode Dynamics 18" and used black anodized aluminum to fill the side gaps. Search for a combination of "DIY" "Heritage Grille" "Diode Dynamics" and you'll find the post and see what I did. I'm very happy with the final product.
2024 Tacoma Heritage Grille -- OEM and Aftermarket Options 2024-11-09 14.49.39a
2024 Tacoma Heritage Grille -- OEM and Aftermarket Options 2024-10-18 17.59.25
That said, DD announced at SEMA that they are switching to the 20" standard in their newest iteration of the product line.
Slappy
tacoma , highlander
Aspire grill no cutouts for light bar/no camera
$289
2 week shipping
looks great silver lettering
2024 Tacoma Heritage Grille -- OEM and Aftermarket Options PXL_20250122_220738268
Love the no sombrero logo look !
i removed all the badges
" Badges ? I don't need no stinking badges ! "
For those that might be interested, I took these measurements when doing my brainstorming:
Grille Opening: 20-3/16" wide x 1-3/16" tall
Grille rear, inside "track": 20-5/8" wide x 1-7/8" tall (flat area behind cutout)
Grille rear, max void: 21-5/8" wide x 2-1/8" tall (angles or taller walls/attachment points)
Using the Diode Dynamics 18", the frame is 19" wide, 19-3/4" wide at the bolt seats. The gap you need to close when centered is 1-3/32" = 19/32" on each side.
bronzebeast
So Cal
2025 DCLB
Using the Diode Dynamics 18", the frame is 19" wide, 19-3/4" wide at the bolt seats. The gap you need to close when centered is 1-3/32" on each side = 19/32" on each side to close out gap.
looking at these measurements I wonder if the cali raised 20”bar would fit. It seems it’s deep, but more shallow than the Baja designs. Has anyone thought about or tried it?
bronzebeast
So Cal
2025 DCLB
Do you happen to know how deep the light bar cavity is? I’m seeing some light bars like Cali raised which extend 3.25 inches back and I’m curious if this would fit in the void or would it be too deep
