Dashcam Hardwire w/o Fuse Box *ALMOST* as easy as Dongar
Halifax, NS
2025 TRD Pro
Underground24
24 Tacoma
Thanks for the post. Are you saying the Dongar Pro doesn't support parking mode for Viofo dashcams? This is contrary to what their website advertises. I don't see anywhere where it says pro not compatible with Viofo?
BoboForShort
BoboForShort
Tyler
The Dongar Pro has it's own "parking mode" where it continues to provide power to the dashcam after the ignition is turned off. This is great for dashcams without their own built in parking mode.
The Viofo has a parking mode (when hard wired) where it detects that the ignition is turned off and it goes into one of several parking modes that either use less power or a lower memory usage.
When you power a Viofo with a Dongar Pro, the Viofo does not know when the ignition is turned off because all it sees is that it is getting USB power. So it will continue to record when parked, but you will not have the advantage of the low power or low memory usage state that the built in parking mode provides.
Kjc
Anc
2024 Tacoma OR
Will one of the Dongar plugs work? I have the Dongar pro and a Viofo... A little upset parking mode doesn't work... Can I pull their wires from one of their connectors and hook to the hardwire kit?
Thanks for the write up... I did the fuse tap after getting pissed at the Dongar pro but I didn't wanna leave it uncovered...
Or splice the hardwire kit to one of these... I was hoping the one on the left?
2024 Tacoma Dashcam Hardwire w/o Fuse Box *ALMOST* as easy as Dongar 20250223_030622
Underground24
24 Tacoma
Thank you for the detailed reply Bobo that clears up a lot!
Looks like Viofo has a hardwire kit and two add a fuses for $22. The taco has mini low profile or mini ats fuses? Guessing there is a constant and switched fuse that I can easily tap into under the passenger side glove compartment box? Thanks!
BoboForShort
BoboForShort
Tyler
Yes, the one on the left will work perfectly. That connector is actually what gave me the inspiration to do this.
I believe the Dongar wires are 22AWG and the Viofo hardwire kits are 20 AWG. So just make sure you use a 22-20 size butt splice wire crimp.
The color codes are the same between the Dongar wires and Viofo hardwire. Just need to cut and crimp.
Reactions: Kjc
BoboForShort
BoboForShort
Tyler
You will need mini low profile fuses. There are fuses in the interior fuse panel under the glovebox that will work. The problem is that there is not enough space between the fuse box and the plastic kick cover to fit an add a fuse so you will need to leave the cover off.
2024 Tacoma Dashcam Hardwire w/o Fuse Box *ALMOST* as easy as Dongar 1712600338621
See the detailed post by Dongar in this thread to see what I mean.
https://www.tacoma4g.com/forum/threads/dash-cam-solutions-for-2024-tacoma.1869/page-2
Underground24
24 Tacoma
Kjc
Anc
2024 Tacoma OR
I wonder if it works also from the rearveiw mirror plug? Did you try there or only from the dome light area? I'm thinking of cutting off the Dongar and splicing to hardwire kit from there
BoboForShort
BoboForShort
Tyler
That would work just fine. It's the same concept. Since you have a premade splitter it should be no problem.
Reactions: Kjc
Josh256
Toronto, ON
2025 Tacoma TRD Pro
I went the FitcamX route which replaced the mirror cover (eg. stealth dashcam) and also included a pass-through power adaptor. It's pricey but nothing on the windshield. Install took 10min.
Reactions: Kjc
TrustButVerify
central
Several
I’ve been enjoying my 2024 Trailhunter for about a month now, and one of my first priorities was installing a dashcam. I initially bought a Dongar Pro after seeing it heavily recommended online. It’s a great product, but it’s not fully compatible with VIOFO cameras, which I wanted to use—specifically, it doesn’t support their built-
in parking mode. I still wanted a clean install, so I started exploring alternatives that didn’t require tapping into the fuse box, which seems to have limited space.
**If you just want to power a camera and don't care about parking mode, use the Dongar adapters. If you want to add a parking mode to a camera that doesn't have a built in one then go with the Dongar Pro. If you have a camera with a built in parking mode and want to use it, read on.**
Here's what you'll need:
A dashcam. I like the VIOFO A229:
https://www.amazon.com/dp/B09MRVP2PX
A hardwire or fusetap for your camera. This is the one for the VIOFO A229
A plug for the OEM dashcam power (90980-12366). Get the female plug with the wires already pinned, trust me. I'm an electrical engineer and thought I would be slick by pinning it myself and it was a huge pain and I gave up after pinning just one wire. You can use a wire tap/splice if you would like but I did not want to cut into the wire harness:
https://www.aliexpress.us/item/3256806039270154.html
Some sort of crimp or solder connector and whatever related tools you need to connect the wires on the plug to the wires for the hardwire kit.
Here's what you'll need to do:
1. Connect the wires from the plug to the wires for your hardwire kit. Black is ground, red is 12VDC constant, and yellow is 12VDC accessory. Wire them as shown in the photo. You can cut the other wires short.
2. Remove the dome light. Pull straight down on the front on both sides. There are 2 red clips that hold it in. I was unlucky and broke one after removing it a few times. You can buy them on amazon.
https://www.amazon.com/dp/B0CGPHRJ8T
3. Plug it into the OEM dashcam plug that should be present on all 2024+ models. Maybe not SR, but I'm not sure. I'd recommend testing it first before mounting and wiring everything in.
ALL DONE! That's it. Pretty plug and play, the only hard part is crimping the wires and waiting for the slow boat from China to deliver the connector.
Some notes on cable routing. The space next to the dome light is fairly cavernous and you should be able to stash most of your excess wire up there.
The clip for the visor comes off with a quarter turn counter clockwise and it lets you pull the headliner down a little to tuck cables and do the final wiring.
If you have a rear camera I would recommend starting from the back and stashing any excess in the headliner once you get to the front. Otherwise it's pretty standard, follow the headliner around to the door seals and then go from door seal to pillar to door seal to pillar in the rear and then tuck the rest into the headliner in the back.
This is great. I have the Dongar, but the camera I have won't work in sentry mode with their system. The system the Pro uses to provide always on power is suboptimal. Cameras are not configured to use parking mode the way the Dongar provides power when the truck is off. Their idea was interesting, but the consequences of it didn't work.
Kjc
Anc
2024 Tacoma OR
Ya I wish they would have specified... I'm not sure how it works with other cameras but with a Viofo it just keeps recording tell it times out or shuts off... It was advertised as actual "parking mode"... I took that to mean shutting down and only turning on with movement or the G-Sensor getting triggered
TrustButVerify
central
Several
On mine, a 70mai camera, it acts the same. Just runs like normal. So no glassbreak, no G sensor, no motion sensor.
Josh256
Toronto, ON
2025 Tacoma TRD Pro
To be fair, it takes all of 10m to route power from the passenger fuse box... You can remove the mirror cover without a pry tool (pop the small top/center cover out using a finger, then slide the large molding downwards). The passenger A-pillar cover comes off with a 10mm socket (use pry tool for 2 bolt covers on the handle) and the headliner is freely accessible between the two.. If you're not buying a pass-through harness to tap 12v/ACC from the mirror assembly this is actually much quicker/easier than DIY splicing into the ACC wiring up top..
Mirror cover a great spot for a compact GPS/cell tracker.. hypothetically, of course;)
