Opening power tailgate if truck has dead battery?
emerica243
Matt
PA
Fusion
Is there a way to get into the bed of a power powered tailgate configuration if the trucks battery is completely dead?
When my tailgate gets out of spec by hitting something the manual says to manually move it to closed, so I assume that you can just pull it open, even with a dead battery.
emerica243
emerica243
Matt
PA
Fusion
How are you actually delatching it with a dead battery? There's no key hole, theres no manual handle mechanism to delatch. It's all electronic button operated.
So if there's no power to the tailgate and you need to get to something in the bed of the truck(cover on) how are you "manually opening it" as you state?
Your idea of just being able to "pull it open" even with a dead battery makes no sense to me. Or else theives would just be "pulling them open" stealing everything when the trucks all locked up? What am I missing here.
Good question - I assumed that you could open it with the tailgate handle. My tonneau needs to be opened slightly or the tailgate stops and warns me. I have to manually move it to closed before it starts powering the tailgate. So I know you can move the tailgate, but I have never tried to unlatch it without power. There might be something in the manual, but good luck finding it. You might also check with your dealer, although they might not know either.
You might try disconnecting the neg terminal and seeing if you can unlatch the tailgate. That piece of knowledge would be a help to a lot of us IMO.
emerica243
emerica243
Matt
PA
Fusion
Yea. Id think more people would be worried about a situation like this, or atleast want to be prepared. For example....my battery booster pack is in the small cubby box in the truck bed.....could be useless.
I'm having a flashback. My wife's BEV's 12 volt went flat and her booster pack was in the hatch, which would not open without power. It is also a Toyota product so your are smart to be looking into this. The tailgate latch is probably the same way in our trucks.
I figured out how to open her doors without power, opened the hood, and put a charger on her battery so we could open hatch, but we would have had a problem if we had been away from home.
Canufixit
Canu
New England
2025 sr DC 4x
Bump Anyone figure it out ...?? I'd hate to have the battery die. What if the E unlock fails?? You can never get it open / have to dismantle the tailgate cover ??? WTF ??? Should the elock/eunlock fail I'd hate to have to slash my $400 Roll up cover just to get something I really need inside (like a battery booster, tools, etc.)
Yotota
SW WA
24 TRD
Unfortunately, I'm 99% sure there is no tailgate solution that doesn't involve restoring 12V power. Everything is the mechanism is electronic and would need to be accessed from inside the bed by disassembling the tailgate panel. I also wouldn't carry a booster pack in the bed though due to PNW moisture and corrosion issues. Just carry it in the truck.
CrispyTaco
2024 Tacoma Off Road Hybrid
my battery died last week and I had no way to open the tailgate. I left my jump starter in the truck bed, luckily i was home and able to use a secondary to start it and open things up. did not recall seeing anything in the manual and the dealer didnt know s**t about how to open it
CrispyTaco
lol i guess i could and test out the tailgate protector plate
Excuse my ignorance as I have a manual tailgate, but you can't open the tailgate if that battery is dead? Like not even with the manual handle?
It doesn't have a manual handle on the power tailgates. It is a switch which activate an electric mechanism, so no power means no way to open it.
