Tonneau cover emergency handle delete
Dayen
Daniel
North Kingstown RI
2024 Tacoma SR 6MT, 1985 BMW 316 5MT, 2004 BMW 325i 5MT (sold)
I've found that when I close the tonneau cover with the tailgate already shut that the emergency release handle gets stuck between the tailgate and the cover and prevents it from closing. Is it okay to delete the handle? I'm thinking I should cut or burn through the plastic carefully to get it off. This is on an OEM hardcover trifold
2024 Tacoma Tonneau cover emergency handle delete 1000019716
Romer
Ken
Centennial, CO
I wouldnt. Sounds to me like you need to loosen the bolts at the other end of the bed and adjust the cover back a smidge. Maybe something else alignment wise is going on.
That handle is also is how I open the panels
Dayen
Dayen
Daniel
North Kingstown RI
There's only 1 handle, the other side and the rest of the pieces you just pull the wire which is totally fine for opening it.
I think it's pretty well aligned, it opens and shuts just fine when the tailgate is down the only issue is the handle interfering when the tailgate is up
Romer
Ken
Centennial, CO
Maybe this will help you. I have the same cover
The handle is very loose on the wire so Gravity on the slack wire will always have it point down. Maybe the slack of the wire or the plastic handle is binding on something.
2024 Tacoma Tonneau cover emergency handle delete 1744927498158-z
Dayen
Dayen
Daniel
North Kingstown RI
It's when I swing the cover shut from it being flipped back, the handle flies out and gets caught... If I close it very slow it doesn't happen but I am impatient ?
ramble22
2024 Tacoma Limited Hybrid
I had the same issue. Ended up just carefully cutting it off with side cutters since the plastic is quite soft. Doesn't serve any purpose other than briefly glowing in the dark after the cover is closed. Was worried that it would eventually cause damage from getting pinched between the cover and tailgate when closing.
Kjc
Anc
2024 Tacoma OR
If it's bothering you I would cut it... It's not necessary... For emergency only ?... But really all you need is the wire... Not the plastic handle
Dirt
Greg
Eastern OR
I just give it a second till it hangs down and then finish closing the cover. I know what you mean 'cause it took me a couple times to learn to take a breath before slamming it.
Halifax, NS
2025 TRD Pro
I feel like I’d have to slam my cover way harder than I ever would to get the same result, I couldn’t imagine doing that to such and expensive piece that probably would bend over time or break
Dayen
Dayen
Daniel
North Kingstown RI
I mean it's a truck, I do truck stuff with it idk
The tonneau cover has plenty of strength to it so I'm not concerned about breaking anything, and the surface area of the piece gives it decent wind resistance so it's not going super fast either.
I'm not slamming it very hard, just dropping it once gravity will pull it down from being flipped. This mostly happens when I drive to the dumpster on my way out somewhere and have the cover flipped up partially so I can grab whatever is in the bed easily
astroboy
Southern California
I took mine out, one reason is that sometimes it rattles. Just be really carefull when you take it out, I slightly knicked the cord when I cut out mine. Not that big of a deal, but still it would have better had I been more careful.
CarpeDiem303
Stephen
Denver, CO
24 TRD Off-road Tacoma
I have the same cover.
I've only had this happen to me once because I open the cover on the other side.
That wire extends all the way thru the cover and so by opening it on the other side keeps the wire taught and that handle up and out of the way.
Airborne
Upstate,NewYork
Velcro is a good idea if you dont want to cut, ive never had an issue with mine, actually was just using tailgate 10 minutes ago, only thing i removed was the blue sticky tape on it .. im really happy with the OEM cover, great fit, no leaks, looks quality
Dayen
Dayen
Daniel
North Kingstown RI
Decided to cut it off, did it very slowly and painstakingly but no damage to the wire!
Now I can shut the cover no problem with the tailgate open, I think it's the way to go
2024 Tacoma Tonneau cover emergency handle delete 1000019763
