1up bike rack and truck cap / AluCab canopy PSA
vanhuette
2025 TRD sport premium
Just got my new 4th gen, swapped over my 1up SD rack for my bikes. It appears that the hitch receiver is mounted further underneath the truck in relation to the tailgate itself on this new gen ... long story short, even with the bike rack backed out as far as it can go in the receiver, there is questionable handlebar overlap with the tailgate. This matters more if you want to put a cap on.
On my previous 2nd gen I had a mid-rise LEER cap and never had any contact with the rear window, however I just dry fit an Alucab and the vertical rear window will 100% be smashed by the handlebar after the first bump. Guess Im looking at the smart-cap with a more angled rear window to gain some clearance
2024 Tacoma 1up bike rack and truck cap / AluCab canopy PSA IMG_1698
2024 Tacoma 1up bike rack and truck cap / AluCab canopy PSA IMG_1688
British Columbia
Tacoma TRD Off Road
I was interested in this canopy so this is very useful info. Do you think there would be enough room to use a tailgate pad with this canopy if you left the rear window open?
vanhuette
No idea but I doubt it, I tried that once with an old canopy and it was a massive headache to try to get them in and out
dlh
Don
Livingston, MT
2025 Tacoma OffRoad DCLB
This can be a general issue with all caps. My Leer cap has not arrived yet, but am working out the fit of my Kuat rack ahead of time. I will probably arrange my wife’s bike toward the bed as it has narrower handlebars. Mine would def overlap past the tailgate. If even that does not work, either a Kuat or 3rd party hitch extensions of about 7”.
HardShellTaco
2004 Tacoma TRD 5MT extra cab, 2025 TRD Off Road 6MT
This is a little off topic, but I hope not by too much. I just got my new TRD Off Road, and haven't put my 1UPUSA rack on it yet. Do you have a routine for disabling towing aids, backup alarms, etc?
dlh
Don
Livingston, MT
I just turn off only PKSB (Parking Assistance Braking Support). Still beeps at me in reverse but no sudden stops and the front parking assistance still works. The tone can be temporary turned off but will come back on next time you go into reverse. You will also get a warning each time you start the truck reminding you this is off.
Cross traffic alert still seems to give valid cross traffic detection.
Others may have different approaches.
vanhuette
This is true, however it surprised me coming from my 2nd gen, with a LEER cap, and having ZERO issues with handlebar contact. I didnt have the rack pulled all the way out of the receiver, and even with my larger bike (wider bars) closest to the truck never came close to to contact. it seems like there is a definite change to where the receiver is located relative to the tailgate, and I suspect people are going to have more issues with caps with 4th gen.
Regarding the hitch extender, I considered that, but wow is it ugly AF and kind of defeats the purpose of how snug to the bumper the rack can be when in the upright position - part of what I like about it is being able to park the truck normally because it isnt adding almost any length
agreed, turned off PKBS so it would stop sudden braking on me, the cross traffic warnings seem pretty good even when the bikes are on there. annoyingly every time I drive it will intermittently have a "PKBS turned off" warning that overlays the dash, and a "trailer detected" warning overlaying the dash. cant seem to find a way to stop those from coming up, although there should definitely be some sort of hitch rack setting that removes those.
mikeymtbs
Atlanta, GA
24 TRD Offroad Premium
Yep, PKSB needs to be switched off. When it beeps while backing up, just tap the speaker icon on the screen to mute it.
RokeHi
TRD PreRunner
The Copper State
After installing my 1UP I shut off the PKSB
rocky.mtn
2024 Tacoma TRD OR (Hybrid)
Exact same thing with my 1UP SD Rack and Alu Cab Contour. Are you sure in saying it will smash?
Trying to figure out the right distance to mount, vs buying a swing out. I may just slit a tennis ball for now and slide it over the bar end and hope its OK.
vanhuette
ya I mean a tennis ball or something might help but I would be pretty worried about the glass. It took no effort at all to push the handlebar into the glass, I’m sure even mild bumps on the road it would be slamming into it. Also my dealer told me a 3 month wait for a replacement glass if it breaks.
for what it’s worth the smart cap has great clearance.
2024 Tacoma 1up bike rack and truck cap / AluCab canopy PSA IMG_1815
rocky.mtn
Yes with my wife’s 760mm bars I have about 3” to the contour glass. Using the tennis ball for now. It’s been ok for several trips and highway compressions. No off roading yet.
Thinking of adding a swing out such as the swagman swivel or a Rigd if I can find one used which would add additional clearance.
The smart cap looks nice, but was a lot more expensive than the contour. That being said, I wish I had thought about the rack clearance.
vanhuette
Agreed, I had initially ordered the alucab because I think they are better made and all one piece which I would have preferred. I much prefer the look of the smart cap but couldn't justify the price just for the aesthetics. However, considering how often I use it for bikes the clearance was abolsutely an issue.
I thought about adding a hitch extender to make it work with the alucab, but I didnt want to drop the hitch (ground clearance/departure angle) or raise the hitch (part of what I love about the 1up is that it clears the lowered tailgate) and a straight hitch extender added 7" of length to the rack, even slammed all the way in, which I wasnt happy with for parking and general use, as my the rack stays on my truck most of the time and I like how low profile it is when raised up against the tailgate.
2024 Tacoma 1up bike rack and truck cap / AluCab canopy PSA IMG_1686
vanhuette
Yeah it definitely does, I can send a photo when I’m back at home if you want. I suspect any rack that folded up against the tailgate would be the same though
