Any alternative to the Rigid SR-L Reverse lights?
Novax
Michael
Novnov111!!!
Tacoma 2024
I recently bought a ARB rear bumper and I saw some people bought lights for it. Has anyone installed something else? because 400 for small lights. I can't justify that.
EastonTaco
Venice FL & Easton PA
Take a look at VLEDS, I put the license plate frame with LEDs on my Sport and am very happy with the extra backup lights, brake lights and running lights. Super easy install if this meets your needs.
StreeTaco
2024 Tacoma TrailHunter
JimScotty0
The Farm, Central Washington
2024 Toyota Tacoma
You could use 2 of these for only $8.60 and still have 8 left over for other uses. It should easily fit on the existing cover but would only give you brake, DRL, or AUX switch lighting. There are many similar products available where you could find White if you only want a reverse light.
https://www.amazon.com/dp/B07V9H5RBJ
I bought a set of these for other possible uses in the future. Can't go wrong for the price point.
2024 Tacoma Any alternative to the Rigid SR-L Reverse lights? 1746384893798-r
PullinDoubles
Bobb
2024 Toyota Tacoma TRD Off-Road i-FORCE MAX
HitchMount LED Pod Reverse Kit.
This isn't exactly what your asking about.
They work well though. Provide a lot of light
And easily removed in a few seconds.
Cheaper of the two just provides a tail light and
A reverse light. Mine was under a hundred on one of their sales. Clicks in to stock wiring in a couple minutes! Diode Dynamics quality!
https://www.diodedynamics.com/hitchmount-led-pod-reverse-kit-for-2024-2025-toyota-tacoma.html
Novax
Michael
Novnov111!!!
Tacoma 2024
Niceeeee. I'm definitely going to look into it
ChrisWhaaaat
Western Canada
2024 Tacoma Trailhunter, 2018 4runner limited/turned off-road, 1977 FJ45
I don’t have a good alternative but you should be able to find the lights for less than $400, either US or Canadian.
I must say though, I bought the lights myself for my trailhunter and got the wiring kit from SPV performance parts and the ease of install and result is 10/10. Everyone who I see with my truck checks them out and is impressed with the look and function.
