Are there any printing services that will do single orders you know of?
I live in a two-light town, and the local library does custom prints. Six-bits says you've got a friend who has one. If you're on Facebook, ask around.
3D prints?
3D prints?
The library here will 3D print for locals. They printed a part for my sliding bevel saw some years ago, and that's when I decided to buy a 3D printer.
Interesting.
No, I know my library doesn't have one. I'm on the finance committee for my town, and nobody is requesting a printer. It would be a tall order for something like that to make it to the final budget without strong justification.
That said, as I think about it, I can see storefronts opening up for 3D printing as it becomes more mainstream.
For automotive use, what type of filament is needed?"
This is what I wrote about it on Thingiverse:
This is a bracket for mounting a single ARB compressor in the engine bay of the 4th-generation Tacomas.
I printed this with PETG with a heat tolerance of 176Âş. In a test run with the bracket in place without the compressor, the temperature of the part was at 127Âş after a twenty-mile run on a hot day. Ask me at 10,000 miles how it's holding up. ;)
Bolt the compressor to the bracket before installing it. I used 5mm socket-head bolts for this. Use 6mm socket-head bolts to bolt it to the truck. Make sure to install washers. You'll need extra-long ball-head Allen wrenches to do this.
Doug
North Oregon Coast
2024 Tacoma Offroad
Anyone seen a cover for the sharkfin antenna that is flat? I'm hoping to place my sharkfin antenna in the dash and cover the leftover hole with a flat piece.
The camper cab over for the the camper I want will hit the sharkfin and I don't want to raise the camper if I don't have to.
I'm sure there are, but I suspect you've got a friend who has a 3D printer.
So... the volume knobs are breaking below the big screens? Mine hasn't, but here's a replacement if you have a printer.
2024 Tacoma My 3D printed parts for 2024+ Tacoma 4th Gen -- bed storage box, flashlight holder, oil change channel, ARB compressor bracket IMG_7855
2024 Tacoma My 3D printed parts for 2024+ Tacoma 4th Gen -- bed storage box, flashlight holder, oil change channel, ARB compressor bracket IMG_7856
You can grab the file over on Thingiverse:
https://www.thingiverse.com/thing:6807426
It's not quite as fancy as the stock part, but it works fine. I'll throw mine in the glove box.
Paul_1978
Paul
2024 Tacoma TRD Sport+ 6M
I printed these inserts to tighten up the glove box, they work great.
Also printed the glove box divider listed earlier in the thread,
The fit of the glove box is strange. It latches into place and has pads on the lid and spring loaded push points on the glovebox. But I can push it further closed when it is latched by maybe 1/2 inch or more. Why so much play?
I think I need to make some of these, although mine don't seem to rattle - at least not yet..
I also want something to cover the cup holders, which I seldom use. It seems like that space could look a lot better with something in it besides a hole.
HBNARO
Scottsdale Az
2024 TRD PRO Terra
