Son drove the truck to school and back, apparently popped it in 4hi
ixo
Rich
Antioch, CA
2024 Hybrid Tacoma OR
This is my first truck, has about 1500 miles at this point.
Son drove my truck to school yesterday and apparently was poking around on the knobs etc, and put it in 4hi. I know you should avoid using 4hi (and lo) on pavement and tight turns, it's best when the wheels are slipping independently, and turns can bind the driveshaft, etc.
We're talking maybe 10 miles tops here for the full round trip, no freeway, maybe 40mph top speed? So not all day or anything, and I'm not sure if it was on the way to school or back. I immedately noticed it felt different this morning, and it took me a sec to realize what was off (it being in 4hi). This is nothing major to worry about, right? I want to just use it as a learning lesson for him (he just got his license) but also don't want to make anything worse or not give it attention if it needs it.
Am I overthinking this?
Delirious
Nick
I did it for about the same distance a few months back and I got up to 65 and 70 for two or 3 miles
I discovered it before I got home and was shocked I couldn't tell the difference because I've always been able to feel it immediately when hitting the asphalt in four-wheel-drive in my other trucks in my past lives. Maybe the all-wheel-drive kept me from feeling it?
Everything's been good since then and I've been more aware of that 4H.
Hopefully I'll never do it again.
EastonTaco
Venice FL & Easton PA
My wife did this on my Gen 3 a few years ago then came home and said something was wrong with the truck, it’s hopping during turns. Turns out she had it 4WD Hi. I talked to the service manager at my local Toyota dealer who said if something broke you would know it. I had the truck three more years and never had a problem. My guess is that you should be OK
LincolnSixAlpha
Phoenix
Wouldn't worry so much on that. I dont Offroad much, although I have many vast deserts around me in which to do so, but at least once a month when I know I'm gonna be driving straight for a few miles or more, I'll flip on the 4 by system just to keep things "exercised" I've noticed the front diff has become quite a bit more smoother in operation since it's getting a good chance to wear in.
Anyhow, the driveline will take a bit more than you can dish out, at least in your mind at this point. if it's driving normal I wouldn't sweat it.
I can't say I've ever heard of anyone destroying a part time 4WD driveline by driving on pavement, although I'm sure it has happened.
wutheck
Jeremy
Sparks Nevada
2024 Toyota Tacoma TRD Sport
My son did the same thing. He gets back home and lets me know the truck stops when he makes turns. Of course he denies messing with the dial. haha No harm done as far as I can tell.
Reactions: ixo
24TacomaGirl
Robyn
Definitely no major concerns (except for gas mileage) at nominal street/highway speeds in 4hi. It can do it, and yes, puts extra wear on the driveline, but it’s designed to be able to do it. Just mileage is all that will suffer!
Reactions: ixo
EastonTaco
In the same vein as the red airplane “Remove before flight” tags, someone needs to make a red “Don’t touch this F#%king button” tag.
kaliforniaman
San Jose, California
2024 Tacoma, 1999 Tacoma, 1998 4Runner
I have always been in the habit of putting my grocery getter in 4H every few months to keep the 4W driveshaft and components lubricated. I usually go up a slow hill, maybe 30MPH, but it’s never been a problem. In snow or ice, much more often. Did this on the 99’ OR, 30 years and never a problem with the 4WD system.
Texas Bob
Bob
Hey, Nick, if your Limited has AWD then it does not have the 4WD drive system that most Tacos have: you have a full-time AWD with a lockable center differential. You're fine on dry pavement all the time without extra wear and tear unless you engage the center differential.
WhakoDog
Only the Hybrid Limited has AWD. Gas is part time 4WD like the others.
Delirious
Nick
Another lying salesman got me. That's one thing I didn't even consider verifying and I missed it when I looked at the window sticker.
I knew you were right, but I just verified it with my window sticker.
Dang. But that's OK. I never thought about the AWD until the salesman mentioned it after I went to pick it up.
Delirious
Nick
Thank you for that but I just found out I do not have the AWD
